HideToHidden –> HideToTrash?
All  1  2-5
7076.2 In reply to 7076.1
.. that should do the trick
script: /* Hide selected objects, and assign to style = Trash */ var gd = moi.geometryDatabase; var styles = gd.getObjectStyles(); var si = -1; for ( var i = 0; i < styles.length; ++i ) { if ( styles.item(i).name.search( /trash/i ) != -1 ) si = i; } if ( si == -1 ) { var style = gd.addStyle(); style.name = 'Trash'; si = style.index; } var objects = gd.getSelectedObjects(); objects.setProperty( 'styleIndex', si ); objects.setProperty( 'hidden', true );
7076.3 In reply to 7076.1
Thanks Marco!
Yes Jay - to change that particular script there are 3 places in it that have the name 'hidden' - you need to change only the first 2 because those are the ones referring to the style name. The third one is referring to the object.hidden object property that controls whether an object is hidden or not rather than a label name.
If you only changed one of the 2 style related ones, or changed the 3rd object property one you would not get the right result.
7076.4
Thank you very much Marco,
thank you very much Michael!
Good to have a script that works so I could figure out my mistake:
I tried it that way - it's a bit embarrassing- but my quotation mark was changed automatically by the text editor.
7076.5 In reply to 7076.4
Hi Jay, your text editor sabotaged you! ;)
Sometimes the fancier "word processing" type editors can be bad for editing program code since they can sometimes mutate the text like that.
Show messages: All  1  2-5
