Create custom default colors?
All  1  2-6
7050.2 In reply to 7050.1
There are ways.
RAL.3dm has a lot of colors.
A nice "jewelry" color set had a "copyright" or somesuch hidden in it, so I had to delete it a while back.
7050.3 In reply to 7050.2
OK. I see then. The trick is to create a template with the colors you like. Thanks!
7050.4 In reply to 7050.3
Hi Chipp, yup that's it - once you have the colors you want set up save that off to a 3DM file and then set that as the startup template under Options > General > Template file.
Then when you start up MoI or do a File > New, the initial styles will come from that file.
7050.5
Here is a link, with a nice template from Marco :-)
http://moi3d.com/forum/index.php?webtag=MOI&msg=5413.1
Selecting OptionsTab, GeneralTab, and clicking on "Edit.ini" button will show the path to the moi.ini file, on Windows7.
(Mine is down 5 subdirectories.)
The ini file has the location of the Startup template: [Settings] Startup template=C:\........
hmm, At work the template is in a moi beta folder with will get deleted. Guess I'd better move it. (to ...appdata...)
Show messages: All  1  2-6
