Why does the Hide shortcut command not work?
All  1  2-6
7049.2 In reply to 7049.1
Hi Chipp - Hide is not exactly what is called a "Command" in MoI since you can run it while in the middle of an already running command. So to invoke it involves a slightly different method of putting in some script code in the shortcut key rather than putting in a command name.
For the specific code to put in, please check the help topic for shortcut keys here:
http://moi3d.com/3.0/docs/moi_command_reference11.htm#shortcutkeys
Scroll down past the command names listing there and the script needed for hide is listed just after those.
7049.3 In reply to 7049.2
I get the same Error when I attempt to evoke the command RingCircle.2
EDITED: 11 Apr 2017 by HOPPER
You must have the 2 files RingCircle2.htm & RingCircle2.js inside your Moi commands folder!
you can call it by press Tab and write ringcircle2 (Capitals are not obligatory but space forbidden)
or make a shortcut!
And replace ringcircle2.htm by this new one
http://moi3d.com/forum/index.php?webtag=MOI&msg=4441.11
for working inside the V 3 !
But I don't know what is the ringcircle! :)
Pipe2 ?
EDITED: 11 Apr 2017 by PILOU
7049.5
Got it thanks!
7049.6 In reply to 7049.3
I also got briefly confused by overwriting the v3 version with the older version.
Show messages: All  1  2-6
