repeating last command
704.1
is there a way to repeat the last command?
If not could there be some kind of shortcut for that ( say by adding shift or ctrl+sihft)
This would be very usefull say when adding points to a curve, not having to go back every time and activating the tool.
thanks
704.2 In reply to 704.1
Hi Moka, there are a few different methods.
First, if you right-click inside a viewport after a command has exited, it will repeat the last command.
Also, there is a "repeat" checkbox in the upper-right area of the screen, below the "Done" and "Cancel" buttons:
If you know you want to add many points, then check that box before you finish the command, and it will automatically repeat until you hit cancel or start a different command. This is the best way to repeat a larger number of times because it repeats automatically without needing any special click or keystroke.
It's also possible to set up a keyboard shortcut to repeat the last command. To do this, go to Options / Shortcut keys, and add a key with the command of "script:moi.command.repeatLastCommand();" . Now when you push that key, the last command will repeat.
