Sub D surface to nurbs smooth
All  1-6  7-19
7038.7 In reply to 7038.6
Yeah, I realize that. I was mostly just dreaming...
But unfortunately, the exports I make are not often quite as good as I need. But it's NOT the fault of MOI. The issue is with the structure and complexity of the CAD files I get from my clients. There are often insurmountable issues with surface geometry, odd tangents, overlapping sheets, etc. Granted, it's not like sub-d would automatically fix any of that. But at least in some cases, it would allow me to go in and smooth out creases or kinks, with proper control over final mesh tolerances.
7038.8 In reply to 7038.7
Programs like 3d Coat and Zbrush have autoretopoloy tools which will get you most of the way there, then you would have to manually retopo some areas to fix up parts of the autoretopo that aren't as good as you like.
There are a lot of people dreaming of exporting nice all quad sub'd meshes from nurbs/CAD packages. If someone develops it they will be on a winner. At the moment those two programs listed above do a pretty good job.
Also take a look at ViaCAD/Shark & FormZ as they have recently released sub'd to nurbs tools.
7038.9
I'm wondering what the development status is of Max's fabulous MoI plug-in. I'm eagerly awaiting the mentioned "Quality" variation of the algorithm, which hopefully will create a truly seamless result, without slightly visible corners / edges in the smoothed object.
— Metin
metinseven.com — 3D (print) design • animation • artwork • illustration • visualization
7038.10 In reply to 7038.3
That looks like it will do the trick. One question though, how do you see the scripts loaded at the bottom of the MOI screen?
I'm a little lost at running scripts here.
Thanks.
7038.11 In reply to 7038.10
Hi pixelplucker,
It's a UI customization that you can get from here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=6507.1
7038.12 In reply to 7038.9
Hi Metin
Sorry, I'm very busy at work last months. I'll try to release it this year.
I'm very close. I need some time to optimise it.
EDITED: 7 Mar 2022 by SMIRNOV
7038.13 In reply to 7038.4
Hi Andrei,
At about 2:01 in the very first Nvil to MOI YouTube video, in MoI you select and edge, then another edge, then you hit a shortcut key to select all the connected edges. What is the script which allows you to selected the connected edges? Thx! Your videos are MOST helpful.
The Video:
https://www.youtube.com/watch?v=k3o9EeVpuhA
7038.14 In reply to 7038.13
Hi Chipp,
Probably the one from here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=6988.4
7038.15 In reply to 7038.14
Thanks, but that expands surfaces, not edges. Is there a script to expand the selection of edges?
7038.16 In reply to 7038.15
script:/*Loop selection*/moi.geometryDatabase.SelectLoop();
There is also a script which will select all the edges of a selected face.. This can be found on the resources page, under pertr's moi page-selection scripts....
7038.17 In reply to 7038.15
chippwalters, looks like I used Loop selection script.
My Portfolio: www.samardac.com
A lot of my Tutorials!
Subscribe to my youtube channel: http://www.youtube.com/samardac
Russian community of MOI 3D: www.vk.com/moi3d
7038.18 In reply to 7038.17
Hi Max,
Amazing smooth result on this quadball-like mesh ... I can't even see the poles when I disable the edges !!!
7038.19
Any update Max ? Need to re-express my high interest into you work :o)
Show messages: All  1-6  7-19
