CustomUI by Max Smirnov
All  1-5  6-7
7019.6 In reply to 7019.5
Hi BurrMan
CustomUi doesn't use records in moi's ini file anymore. Now it uses moi.filesystem.getUIDir() function.
7019.7 In reply to 7019.1
Hi matur61, if you're not seeing anything different in the UI then it means that the CommandBar.htm file must not have been replaced - when you install the CustomUI you need to let it overwrite one file to get the changed UI.
You might try unzipping it into some other folder like your desktop first and then moving the files over instead of trying to unzip it directly. Whatever you are using for unzipping may not be allowed to make changes into the \Program Files folders.
Show messages: All  1-5  6-7
