screen cap check
All  1-2  3-8
7014.3 In reply to 7014.1
Hi Burr, probably what you're seeing is that script is using a square for the pixel dimensions, that's the ( 2560, 2560 ) part. Probably your regular on screen viewport is not square, it's probably a wide rectangle.
That script is not exactly an on-screen capture, the call the renderToClipboard sets up a kind of in-memory window of the given pixel dimensions and then draws things into that and then puts that on to the system clipboard.
If you modify the script to be something closer in aspect ratio to your regular viewport dimensions it will probably work better for you, try something like (2560, 1920) .
Or maybe instead of generating an image to a specific custom width and height you'd rather do an actual direct screen capture, that would be like this:
script: /* take screenshot and save to file */ var img = moi.view.screenshot( 'viewpanel', false ); var name = img.getSaveFileName(); if ( name != '' ) img.save( name );
The one that takes a custom resolution one was originally meant so that you could generate an image that was larger than your montior, instead of being limited to just directly what you see on screen. But your screen is large enough that you're probably fine doing a direct screenshot.
7014.4 In reply to 7014.2
Hey brian,
I just wanted to be sure it was working for others before i chase that.
Does it capture your entire 3d viewport?
7014.5 In reply to 7014.4
Hi Burr yeah your script is working here, but it generates a square image, probably your viewport is not square and that's the mismatch.
The other kind of screenshot above should probably work better for you since it will snapshot your actual screen rather than generating a brand new image.
7014.6 In reply to 7014.3
Hi michael,
I see. In the past, i thought those were working under the hood and generating custom resolutions, not tied to my monitor. Limited only by my card... i had a few different ones, like up in the 4000 range... i guess i never realized in my tests that it was truncating the result?
7014.7 In reply to 7014.6
Hi Burr,
Well yeah that's actually exactly what it is doing - but when you use a custom resolution that is totally separate from your current monitor display it's basically as if you have resized the MoI window temporarily to that particular custom size, so it can easily be a different size image than the current on screen image width and height.
Does that make sense?
7014.8 In reply to 7014.7
Yes, thanks. I misunderstood what it was doing originally. I can reset the scripts accordingly....
Show messages: All  1-2  3-8
