"Scale Array" Problem in the V3
All  1  2-4
6998.2 In reply to 6998.1
Hi LY_677 - re: Scale array - it seems to be working fine for me in the v3 final version. What problem are you seeing specifically, have you remembered to create a point object that is included along with the arrayed objects? ScaleArray requires a point object to be included as one of the arrayed items and it uses it for the scaling origin for each set.
Here's what I tested with:
If you're still having problems with it please let me know more specifically what problem you're seeing and maybe post a sample file that is not working for you.
6998.3 In reply to 6998.2
Hi Michael,Problem:Enter "ScaleArray" in MoI v3.0 trial ,Command Options flashed disappeared, no longer appear. thanks!
EDITED: 3 Nov 2014 by LY_677
6998.4 In reply to 6998.3
Hi LY_677 - that type of flash would happen if you do not have the objects to process all selected before running the ScaleArray command. Also there must be a point object (Draw curves > More > Point) that was arrayed with all the objects, the point is used for the scale origin point for each group of items.
If you do not have any selection, or did not include a point then you would get the type of result that you describe.
If you're still having problems can you please post the 3DM model file with the objects in it that you're trying to scale?
Show messages: All  1  2-4
