difficult to fillet
All  1-4  5-12
6986.5
Seems to work out with a 0.9cm 'Const Dist' fillet.
6986.6 In reply to 6986.1
Hi Wim, I've been trying to fillet your same shape in some other CAD programs and they seem to have problems too getting a fillet radius of 1 unit there.
I think it's related to a bit of a tighter than you'd think amount of curvature in the bottom semi-circle shape (screenshots here from Rhino):
That semi-circle like shape is only an exact circular arc on this left part here:
On the right part it's a general curve and right near the end where the control points are kind of close together, the curvature of the curve in that end spot is actually 0.7 units, a fair amount more tightly curved than the rest of the curve:
I had to measure it with the Curvature command in Rhino to really see what the curvature at the end was. This tight curvature at the very end is what is likely limiting the fillet radius as well, because just in general if you try to offset something (fillets involve offset surfaces as part of their calculation) of a distance that is greater than the radius of curvature at a particular spot, it results in a bunching effect like this:
So anyway I think it's this that is causing your fillet difficulty, a kind of hard to see tightening of the curvature right on the back end of the bottom semi-circular shape.
So probably the easiest way to solve it is to make the bottom an exact semi-circle rather than half circle and half general curve, that will change the shape somewhat is that acceptable for what you need?
I have attached a 3DM file with a version where I have done that - replaced the bottom part with a revolved exact semi-circle, this version should fillet for you at radius = 1 without any problems. Again, note that this is a slightly different shape in the bottom rounded area than your original model. If that existing shape is important to you, moving that second control point in the current tightly curved end just downwards by 0.15 units is enough to make the curvature over 1 unit at the end of the curve so that would be a pretty minimal change.
EDITED: 20 Oct 2014 by MICHAEL GIBSON
6986.7
it must be something at my side, I tried with your file Michael, and it works splendidly. but if I generate my own perfectly circular shapes, it fails. I even simplified the shapes, I use quarter and half circular arcs only, but still get no further than .6 cm.
o, btw, I just discovered these answers now and by accident, the number after my title in the left column of the forum in my browser (firefox) still said [1], which made me think that there were no answers yet. I opened my thread by accident and saw all these entries. strange...
Size: 61.2 KB, Downloaded: 28 times, Dimensions: 634x357px
Size: 35.4 KB, Downloaded: 27 times, Dimensions: 524x303px
Size: 38 KB, Downloaded: 15 times, Dimensions: 407x360px
6986.8
screenshot of browser
Size: 62.3 KB, Downloaded: 26 times, Dimensions: 678x339px
6986.9
Michael,
I just saw that V3 is officially available. could it be that it is some instability of my beta jun-27-2014 version?
I'll upgrade this week.
wim
6986.10 In reply to 6986.9
Hi Wim,
No, it doesn't seem to be related to that. And I can't see anything wrong with your object, this one looks like a fillet bug in MoI. I am able to fillet this one in other software, I have attached one version here with the fillet completed so you can have it finished up.
re: forum in web browser - the forum does not automatically refresh so if you've had the same page open for a while that's normal that the left pane will stay the same, you can hit F5 or click the "Discussions" link on the top bar or also the "Topics" text at the top of the threads list to get a refreshed topics pane.
6986.11 In reply to 6986.9
The fillet bug itself is rather mysterious I'm afraid, it seems to be some failure in dealing with the inside vertical wall against the curved top arch.
6986.12
Thanks Michael, I'll use your file for the moment. this job is just for illustration, no accuracy required ;-)
rgds
wim
Show messages: All  1-4  5-12
