harp
All  1-5  6-20
6981.6 In reply to 6981.1
Hi ska234
There are some pictures of a Blue carbon fiber harp here, which show the knee.
http://www.blevinsharps.com/index.php?main_page=index&cPath=342
Consider the strings as residing in a vertical plane, at the center of the soundboard.
The strings are attached to "pins", which offsets them from the top "harmonic arm", by a fraction of an inch/cm.
The harmonic arm is (mostly) just a flat board, with various curves cut with say a bandsaw.
The harmonic arm is located on one side of the center plane, except for a part of the knee.
So to finish the knee, add on another block of wood, which begins at the base of the pins, and extends across the center plane,
over to the other side of the sound board structure. Remove parts of this block to match up with the arm, with say arcs, as per PILOU,
(Of course the harmonic arm could be carved out of one piece of wood...)
EDITED: 15 Oct 2014 by BEMFARMER
Size: 84.3 KB, Downloaded: 39 times, Dimensions: 354x234px
String length, in case someone decides to build a harp :-)
http://www.harpsatsang.com/harp_design/data/stringcalculator.html
Also, a free music Notepad program can be downloaded.
6981.8 In reply to 6981.5
Hello, and thanks for the answers and ideas,
I started with the cube,
and when I try to draw curves through the cube,
it cuts either nothing, or strange results.
(I went through the tutorials and can make crowns :-)
maybe it´s just a lack of imagination what exactly needs to be done?
by the way:
the picture from the harp is carved by hand, band-saw etc.
My skills are there - still It would be so handy to have this drawn.
best regards, ska234
6981.9 In reply to 6981.8
Hi ska234,
Could you please post an attachment of the 3DM files with the cube and curves you've drawn so I can take a look at your geometry?
That will help a lot to better diagnose what's going wrong with those cases, it's a lot easier to tell what's going on when I'm able to examine your objects, repeat the boolean steps, look at things from different angles, zoom in, etc...
6981.10 In reply to 6981.8
sure!
6981.11 In reply to 6981.10
Hi ska234 - thanks for posting the file!
So I think what you're running into is trying to use 2 cutting curves that happen to touch each other at a shared endpoint. The booleans will try to automatically join together curves as a part of the boolean process and in your case here for example:
if those 2 cutting curves get joined together since they're on different planes the resulting joined curve is not on a single plane anymore and so does not know which direction it should be extruded in to form the cutting surfaces.
In case like that with 2 curves in different planes coming to a shared endpoint you will need to do the boolean in 2 passes, one for each individual curve rather than using both curves in the same single boolean operation.
Is that one of the things you're running into?
If it's not that and you're having a problem with one of the other curves maybe you can post a file with just the one solid and one curve in it so I can know for sure which particular one is giving you the trouble.
6981.12 In reply to 6981.11
Hi again,
I am one step ahead,
but the upper shape is tricky...
I tried Boolean, or projekt,
the results are inpredictable...
Any ideas?
Best wishes! ska234
Your picture looks similar to "gwen".
http://artefakt-musik.de/gwen.htm
Most of the harp pictures are at an angle.
The top of the korpus (Sounding Board) is (CORRECTION) 8 sided.
EDITED: 16 Oct 2014 by BEMFARMER
6981.14 In reply to 6981.12
6981.15 In reply to 6981.13
I think it's actually Bluebell, because..
6981.16 In reply to 6981.12
Hi ska234,
Is it with this curve here? :
It looks like the problem is that curve is not planar, it swoops around in 3D space a bit, I think because this particular control point is just slightly not in the same plane as the others:
I drew in a plane using Draw solid > Plane > 3pt, then enlarged it slightly using the edit frame in the corner, then I projected the curve onto that plane:
The result is in the attached 3DM file, it should now do a boolean with it - the booleans won't work with non-planar 3D bending curves because they don't know which direction they should be extruded out into with the automatic extrusion processing.
You may need to use View > CPlane to set your drawing plane, or put in a plane like I've done above and draw on that to make sure the points you are placing are all on one plane. Hope this helps!
6981.17 In reply to 6981.15
Hmm, Bluebell looks different. Gwen has a different top. Must be a hybrid.
This picture looks close. I think there are 31 strings.
EDITED: 18 Mar 2017 by BEMFARMER
Lots of harp information here:
http://harpomania.blogspot.se/
Includes fairly good translations from French.
I might try making a harp this winter, but will probably loose interest first.
6981.19
Hi ska234:
As Max correctly says,harp is made by different pieces joined together as picture shows,so you can model pieces separately
To achieve the shoulder you need to consider the whole pieces of the harp to get correct shapes.I attached the file of my test
take a look at the layers so you can understand how i did the pieces
Use it and if you like,do the rest :)
M
EDITED: 3 Feb 2022 by M-DYNAMICS
6981.20
thanks to you all so far !
I managed to draw it myself now.
Show messages: All  1-5  6-20
