harp
All  1-14  15-20
6981.15 In reply to 6981.13
I think it's actually Bluebell, because..
6981.16 In reply to 6981.12
Hi ska234,
> I tried Boolean, or projekt,
> the results are inpredictable...
Is it with this curve here? :
It looks like the problem is that curve is not planar, it swoops around in 3D space a bit, I think because this particular control point is just slightly not in the same plane as the others:
I drew in a plane using Draw solid > Plane > 3pt, then enlarged it slightly using the edit frame in the corner, then I projected the curve onto that plane:
The result is in the attached 3DM file, it should now do a boolean with it - the booleans won't work with non-planar 3D bending curves because they don't know which direction they should be extruded out into with the automatic extrusion processing.
You may need to use View > CPlane to set your drawing plane, or put in a plane like I've done above and draw on that to make sure the points you are placing are all on one plane. Hope this helps!
6981.17 In reply to 6981.15
Hmm, Bluebell looks different. Gwen has a different top. Must be a hybrid.
This picture looks close. I think there are 31 strings.
EDITED: 18 Mar 2017 by BEMFARMER
Lots of harp information here:
http://harpomania.blogspot.se/
Includes fairly good translations from French.
I might try making a harp this winter, but will probably loose interest first.
6981.19
Hi ska234:
As Max correctly says,harp is made by different pieces joined together as picture shows,so you can model pieces separately
To achieve the shoulder you need to consider the whole pieces of the harp to get correct shapes.I attached the file of my test
take a look at the layers so you can understand how i did the pieces
Use it and if you like,do the rest :)
M
EDITED: 3 Feb 2022 by M-DYNAMICS
6981.20
thanks to you all so far !
I managed to draw it myself now.
Show messages: All  1-14  15-20
