Flipping polygon normals
All  1-2  3-6
6980.3 In reply to 6980.2
Thanks for the fast reply.
Is there a separate command to create a solid ? I joined all surfaces and assumed that creates a solid, but the normals are still not aligned.
This is what the Obj looks like in Softimage:
When I then flip the polygons in Softimage, I have to delete the included usernormals to see the result. Otherwise flipping the normals has no effect. But when I don't use the usernormals I get smoothing artifacts. The solution would be to export a extremely high rez Obj, but that's not always an option.
You can see the smoothing artifacts after flipping the polygons in Softimage and deleting the usernormals in this image:
I've put the .3dm file here as well : https://www.dropbox.com/s/fgtzf2qw8eqdqao/montage_3_poot_final_v02.rar?dl=0
Thanks again,
-Ronald
6980.4 In reply to 6980.3
Ah, I found a command to flip the usernormals in Softimage. That seems to solve the problem for now :-)
-Ronald
6980.5 In reply to 6980.3
Hi Ronald,
No, just if you join together all pieces that touch each other so that all edges are joined between 2 surfaces, that makes a solid. When you have a solid, it will read as a "solid" as the object type in the properties panel:
If it reads as a "Joined srf" or "Surface" rather than "Solid" then it means there are some holes in the model where edges are not aligning closely enough with each other to get joined. To see where those edges are you can set up a "Select naked edges" script on a shortcut key as described here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=6051.2
I think it's because there are some squished down degenerate surfaces in there as well. If you have surfaces with self-intersecting trim boundaries or surfaces that are effectively squashed down to a line with no surface area those kinds of things can mess up the face traversal that the meshing mechanism uses to keep consistent face normals.
Here's one such little slivery surface that I found here:
Good!
6980.6 In reply to 6980.5
Great, thanks for the tips. When I look closely I see a lot of suspect surfaces like the one you pointed out.
I did a lot of the filleting in Viacad because Moi refused to. I think that was bad idea after all, it probably created a lot of the messy faces.
Looks like I have some cleaning up to do.
-Ronald
Show messages: All  1-2  3-6
