UI menu
6968.1
I would like to modify the panel of the UI as illustrated in the file attached
and would appreciate your tips how to achieve it.
I use MOI V2 / german
Size: 75.8 KB, Downloaded: 123 times, Dimensions: 317x1200px
6968.2 In reply to 6968.1
You need to edit the content of /ui/SidePane.htm file.
EDITED: 7 Mar 2022 by SMIRNOV
6968.3 In reply to 6968.2
I had a look at the sidepane file - unfortunately I am not familiar with the language spoken there ;-)
6968.4 In reply to 6968.3
Hi Tom, probably the easiest thing to try is to replace your SidePane.htm with the modified version that Max attached above, although that one is for v3. It may work for v2 too but I'm not sure, it would be better to use it with v3.
6968.5 In reply to 6968.4
I replaced it but it does not work.
Did not upgrade yet because I use MOI just a handful of times a year
but will think it over
