Named View
 1-17  18-27
6962.18 In reply to 6962.16
Hi Paul, it's a really great looking result!
I'm going to be doing some exploration work on a 64-bit version for v4. There will be a lot of work involved in doing it and so I'm not entirely sure yet if I'll be able to do it or not but I will be investigating it.
Seems all the memory is consuming by the wheels ?
As soon as an instance system will be avaible some problems will be resolved ?
6962.20 In reply to 6962.19
Yes, it will probably help out a lot for cases like this with complex repeated pieces.
6962.21
Could the memory issue be solved staying in 32-bit if moi had an instancing mechanism?
Great model btw.
M.
6962.22 In reply to 6962.21
Hi Max,
Not in all cases, but in quite a lot of cases yes I think that's correct that instancing would help even more than being 64-bit.
6962.23 In reply to 6962.17
Hi Martin,
One render. Credit for the background image belongs to the ALMA telescope.
Hope you like it.
Paul
Size: 147.6 KB, Downloaded: 138 times, Dimensions: 1063x808px
6962.24 In reply to 6962.18
Look forward to a 64bit version (should it arrive).
Thanks for all your help.
Paul
6962.25 In reply to 6962.23
Looks pretty good from here :)
Thanks for posting the result
Martin Spencer-Ford
6962.26 In reply to 6962.23
That is a very impressive model and render. Thanks for sharing it.
_________________________
Don Cheke
Visit: Textual Creations
6962.27 In reply to 6962.23
Hi Paul, it looks great!
Show messages:  1-17  18-27
