Shortcuts for turning on the filter-mode on curves, edges or faces?
All  1  2-6
6942.2 In reply to 6942.1
Hi Max, you can put the following scripts on a shortcut key for turning on these particular filters:
script: /* Turn on selection filter for Types > Curves */ moi.selection.setFilter( 'Types', 'Curves', true );
script: /* Turn on selection filter for Types > Edges */ moi.selection.setFilter( 'Types', 'Edges', true );
script: /* Turn on selection filter for Types > Faces */ moi.selection.setFilter( 'Types', 'Faces', true );
That will only turn it on, not toggle it, but you can push the Esc key to turn off filters.
If you want other ones, the script access is through moi.selection.setFilter( category, item, enable ), where:
// Category is one of: "Types", "Styles", or "Names".
// For Types, item is one of: "Curves", "Surfaces", "Solids", "Edges", "Faces", or "Points".
// For Styles, item is an integer number of the style index.
// For Names, item is the string name.
6942.3 In reply to 6942.2
Thank you, that was incredibly quick.
Max.
6942.4
Just to know, is there a 'clearfilters()' function or something? I do not wish them to stack. For now I've been editing those scripts you wrote and adding some false values to the others.
Max.
6942.5 In reply to 6942.4
Hi Max, yes the script for clearing all filters is: moi.selection.clearSelectionFilters();
The related selection filter functions available to script are:
moi.selection.clearSelectionFilters(); // Clears all selection filter.
moi.selection.anySelectionFilter( category ); // returns true if any selection filter is set in the given category.
moi.selection.isFilterActive( category, item ); // returns true if the selection filter of the given category and specific item is active.
moi.selection.setFilter( category, item, enable ); // Sets a specific filter to active or inactive.
moi.selection.passesSelectionFilter( obj ); // Returns true if the given object passes all active selection filters.
6942.6
Thank you!
M.
Show messages: All  1  2-6
