BBS forged monoblock racing wheel kit modelling
 1  2-21  22-28
6937.2 In reply to 6937.1
Looking good again Arian, swift modelling style on this one and good clean looking blends/fillets on joining areas. If you check on my grabcad page you will find some snap fit valves there if you want to use them as reference materials :)
Martin Spencer-Ford
6937.3 In reply to 6937.2
Thank you very much Martin! :)
Yep i tried to follow a workflow cleaned as possible to create nice fillets :)
Later i'll post some upgrades of the wheel....i added some new works on it and i've ended it :) (i've still to do the air valve and the nuts too....)
Arian DESIGN
www.arianshamil.com
6937.4
Here we are...the wheel is now complete......I'll add the air valve and the nut soon :)
I've tried to reproduce the CNC works normally present on these wheels...
Arian DESIGN
www.arianshamil.com
6937.5 In reply to 6937.4
The wheel is looking very good, I hope to see a close up of those milled areas in the render.
Martin Spencer-Ford
6937.6 In reply to 6937.4
Looking very nice Arian!
6937.7 In reply to 6937.5
Thanks Martin! I'll do that! I'll do some detailed renderings ;)
Arian DESIGN
www.arianshamil.com
6937.8 In reply to 6937.6
Thank you Michael :)
Arian DESIGN
www.arianshamil.com
6937.9
Little upgrade....Air valve done....
This evening i'll post the nuts...so the first wheel kit will be ready...
Arian DESIGN
www.arianshamil.com
Micro detail!
Size of the file must be gorgeous when it's will be multiply! (wheels) ?
So I suppose that you ara waiting an instance system objects ?
EDITED: 28 Sep 2014 by PILOU
6937.11 In reply to 6937.10
Ciao Pilou!
Yes the files starts to be quite big doing istances.....but i will duplicate objects on the rendering program....here on Moi i'm modelling just some assembly (brake kit, wheel kit) and i'll do the top assembly on rendering program :)
(but when i'll have finished all the project (tire, wheel and brake) i want to try to create the top assembly on Moi to see how it works :)...I'll try it
Arian DESIGN
www.arianshamil.com
6937.12
ok....Finally I've complete the wheel kit (Wheel, air valve and nut)
Here some pictures :)
Will follow some rendering soon :)
Arian DESIGN
www.arianshamil.com
6937.13
It's a pleasure too see you working.
Bravo.
Massimo.
6937.14 In reply to 6937.13
Thank you very much Massimo :)
Arian
6937.15
sorry for the late but i'm really busy in these days...
here some renderings ;)
Not painted version:
Painted version:
Arian DESIGN
www.arianshamil.com
6937.16 In reply to 6937.15
Very nice Arian, thanks for sharing the renderings!
6937.17
Thank you very much Michael :)
Arian DESIGN
www.arianshamil.com
6937.18
Arian!!! How did I not see this?
What a beautiful result!
Thanks for showing us your progress.
6937.19 In reply to 6937.18
Thank you very much Mike!
Arian DESIGN
www.arianshamil.com
6937.20
Renders up nicely Arian :)
Martin Spencer-Ford
6937.21
Thank you very much Martin :D
Arian DESIGN
www.arianshamil.com
Show messages:  1  2-21  22-28
