V4 Wish List
 1-20  …  521-540  541-560  561-575
6925.561 In reply to 6925.560
Hi WN,
> Thank you, everything works, the other tabs are closed but I think I'll figure it out, or
> as you say it will take a couple of seconds.
Hmmm, yes it looks like when the startup scripts are run the main window has not yet been sized and that then runs into some trouble with the mechanism that compacts side pane palettes when the window is sized smaller.
I'll see about running the startup scripts slightly later than they currently are so the original script can work ok.
6925.562
Currently the IncrementalSave feature (which I use all the time) adds a two digit suffix.
Could there be a way to specify the number of digits, say 3 or 4?
Perhaps some entry in the .INI file?
Thanks much.
Frederick
6925.563 In reply to 6925.562
First save as ...99 :-)
6925.564 In reply to 6925.562
Hi Frederick, yes like Brian writes above the IncrementalSave is not limited to only do 2 digits, it will go up to as many digits as you need.
The only part about 2 digits is that it adds a 0 padding in front if it would otherwise only be making a single digit.
One thing that I could do to make the zero padding more flexible would be to pay attention to any zero padding in the current filename and make sure to maintain it. So that way if you wanted 4 digits you could name your current file file_0001.3dm and then it would make file_0002.3dm, etc... - no ini setting required with this method.
6925.565 In reply to 6925.564
My bad - I wrongly assumed that seeing 01, 02, 03 that it was limited to 2 digits.
So could you have an entry in the INI file that specified the format of the suffix?
Nothing fancy, perhaps just allowing for letters and a place holder character for the digits.
For example an entry of " v0000" would append " v0001" , " v0002 ", " v0003", etc (without the quotes of course).
But your idea of using the end of the first file name I create would work as well - but it requires me to remember to do it - which, at my age, may or may not happen. ;)
Thanks.
Frederick
6925.566 In reply to 6925.565
Hi Frederick, I've set it up using the method of preserving existing padding.
If you forget there isn't much consequence, it will still save.
6925.567 In reply to 6925.566
So if I create the first file and it ends in " v0001" the next incremental save would end in " v0002"?
Frederick
6925.568 In reply to 6925.567
Hi Frederick,
Yes, in the next v4 beta that's how it will work.
6925.569 In reply to 6925.568
I am now a happy camper!
Thanks much.
Frederick
6925.570
Hello Michael,
Hmm... Maybe I missed something.
Does the Detail button not provide the opportunity to copy the value of a Dimension?
6925.571
Is the value of the decimal precision property preset (Options / Dimensions / Formatting / Decimal display) available for read access via the API anywhere? Thanks.
--Larry
EDITED: 22 Oct 2020 by FAHNOE
6925.572 In reply to 6925.570
Hi Mindset, re:
It does not, but that is a good idea to put in.
6925.573 In reply to 6925.571
Hi Larry,
Yup, you can get a list of annotation presets using moi.geometryDatabase.getAnnotationPresets(); , and then each preset object has a whole bunch of properties on it:
   presetName
   presetIndex (read-only, position in preset list)
   setFont() (function that will show font picker dialog)
   fontName
   fontPtSize
   fontStyleName
   fontWeight
   fontStyle
   fontUnderline
   fontStrikeout
   textDisplayMode
   textAlign
   scaleMode
   height
   textAnchor
   textBoxOutline
   textBoxOutlineWidth
   textBoxOutlineWidthModelUnits
   textBoxPaddingX
   textBoxPaddingY
   textBoxPaddingXModelUnits
   textBoxPaddingYModelUnits
   arrowheadType
   arrowheadArrowLength
   arrowheadArrowLengthModelUnits
   arrowheadArrowWidthFactor
   arrowheadOpenArrowLength
   arrowheadOpenArrowLengthModelUnits
   arrowheadOpenArrowWidthFactor
   arrowheadTickLength
   arrowheadTickLengthModelUnits
   arrowheadTickLineWidth
   arrowheadDotSize
   arrowheadDotSizeModelUnits
   arrowheadReverse
   arrowPosition
   outsideLineLength
   outsideLineLengthModelUnits
   outsideDrawLineAcross
   extensionLength
   extensionLengthModelUnits
   extensionGap
   extensionGapModelUnits
   arrowLineExtension
   arrowLineExtensionModelUnits
   formattingDistanceDisplay
   formattingFractionalPrecision
   formattingDecimalPrecision
   formattingDecimalShowTrailingZeros
   radialDimensionRadialType
   radialDimensionCrossSize
   radialDimensionCrossSizeModelUnits
The one for Formatting > Decimal display is the formattingDecimalPrecision property, it can be an integer number from 0 to 7 for the number of decimal places to show.
6925.574 In reply to 6925.573
Awesome Michael, you've thought of everything!! I'll give it a whirl.
--Larry
Message 6925.575 deleted 16 Jun 2024 by IGNITER
Show messages:  1-20  …  501-520  521-540  541-560  561-575
