V4 Wish List
 1-9  …  510-529  530-549  550-569  570-575
6925.550
I've been using MOI for some time now. It's never let me down. The only thing I'd LOVE to see is a Linux install. :)
EDIT: I did a quick search on the forums and see that some are already using Wine. I gave it a shot! So far, so good. :D
EDITED: 7 Oct 2020 by ANOROC
6925.551
Hi All,
I know that my comments are likely quite late but being a very frequent and satisfied user of Moi3D I would like to chime in with just a few wishes that would make my Moi3D user experience just a tad better:
* In the drawing I make I often have quite a lot of different objects and to me it would be feasible if it was possible to group them in "folders" sort of like what happens in windows explorer (Win7). This way a given structure could be "packed" in one folder and "clicked open" when the objects of that structure was worked on.
* Also, also considering the many objects, I sometimes find that it would be helpful if it was possible to describe what a certain object is, i.e. what it does, why it is designed as it is, and why it is placed where it is (etc.). I was thinking that it could be a note that could be attached to the object (after it was named) and maybe displayed just below the object name at the (default) right top of the UI.
* And then a wish I have made before which is to see the individual files as a thumbnail when browsing windows explorer. IMHO it would make it easier to browse drawings with many iterations so that the individual changes between each file was clearer e.g. when returning to the files after some time.
Smaller wishes to a software that I am really satisfied and pleased with ;-)
Cheers,
Jesper
P.S.: Please disregard if someone else has already mentioned this ...
6925.552 In reply to 6925.551
Hi Jesper, thanks for the feedback! Your #1 and #3 are definitely on my radar but it will need to be for a future version not v4 which is very nearly wrapped up.
6925.553 In reply to 6925.552
Hope life is well in these different times ;-)
... & also pleased to hear that you will consider my suggestions in due time ...
I am BTW looking forward to trying the V4 when time allows.
Cheers,
Jesper
6925.554
Hi, Michael.
I think the dimensions tab should be open by default since it is used more often. Or make a lock for tabs that are open by default.
Or add the necessary parameters in the ini file. Also, in the settings of the text insertion tool, I need a parameter lock, for example,
I mostly use curves and I have to configure it again every time. Some settings I can make, but due to reinstalls, these settings are forgotten and lost.
I'm interested in your opinion.
6925.555 In reply to 6925.554
Hi WN, well for both of those things you only have to change the setting one time in a whole program session. Different defaults would only save you like a couple of seconds for the entire program run.
It is possible to set these through script though, so if you place the attached SetDefaults.js file into the MoI appdata startup folder, that should set those up when MoI is launched.
6925.556 In reply to 6925.555
Hi, Michael.
I'm probably doing something wrong, it doesn't work.
6925.557 In reply to 6925.556
Hi WN, are you using version 4? Where have you placed the SetDefaults.js file?
6925.558 In reply to 6925.557
Hi, Michael.
G:\Program Files\MoI 4.0 beta Sep-10-2020
C:\Users\Vladimir\AppData\Roaming\Moi\SetDefaults.js
6925.559 In reply to 6925.558
Hi WN,
It should go in the startup folder in there:
C:\Users\Vladimir\AppData\Roaming\moi\startup\SetDefaults.js
6925.560 In reply to 6925.559
Hi Michael.
In this directory are the files of Maxim and it confused me, I just had to try.
Thank you, everything works, the other tabs are closed but I think I'll figure it out, or as you say it will take a couple of seconds.
In SidePane, I swapped lines 234 and 235, an open tab with dimensions became available, which is exactly what I need. The rest is from your script.
Thank you for your help.
EDITED: 19 Oct 2020 by WN
6925.561 In reply to 6925.560
Hi WN,
Hmmm, yes it looks like when the startup scripts are run the main window has not yet been sized and that then runs into some trouble with the mechanism that compacts side pane palettes when the window is sized smaller.
I'll see about running the startup scripts slightly later than they currently are so the original script can work ok.
6925.562
Currently the IncrementalSave feature (which I use all the time) adds a two digit suffix.
Could there be a way to specify the number of digits, say 3 or 4?
Perhaps some entry in the .INI file?
Thanks much.
Frederick
6925.563 In reply to 6925.562
First save as ...99 :-)
6925.564 In reply to 6925.562
Hi Frederick, yes like Brian writes above the IncrementalSave is not limited to only do 2 digits, it will go up to as many digits as you need.
The only part about 2 digits is that it adds a 0 padding in front if it would otherwise only be making a single digit.
One thing that I could do to make the zero padding more flexible would be to pay attention to any zero padding in the current filename and make sure to maintain it. So that way if you wanted 4 digits you could name your current file file_0001.3dm and then it would make file_0002.3dm, etc... - no ini setting required with this method.
6925.565 In reply to 6925.564
My bad - I wrongly assumed that seeing 01, 02, 03 that it was limited to 2 digits.
So could you have an entry in the INI file that specified the format of the suffix?
Nothing fancy, perhaps just allowing for letters and a place holder character for the digits.
For example an entry of " v0000" would append " v0001" , " v0002 ", " v0003", etc (without the quotes of course).
But your idea of using the end of the first file name I create would work as well - but it requires me to remember to do it - which, at my age, may or may not happen. ;)
Thanks.
Frederick
6925.566 In reply to 6925.565
Hi Frederick, I've set it up using the method of preserving existing padding.
If you forget there isn't much consequence, it will still save.
6925.567 In reply to 6925.566
So if I create the first file and it ends in " v0001" the next incremental save would end in " v0002"?
Frederick
6925.568 In reply to 6925.567
Hi Frederick,
Yes, in the next v4 beta that's how it will work.
6925.569 In reply to 6925.568
I am now a happy camper!
Thanks much.
Frederick
Show messages:  1-9  …  490-509  510-529  530-549  550-569  570-575
