V4 Wish List
 1-8  …  449-468  469-488  489-508  509-528  529-548  …  569-575
6925.489
My number 1 wishlist item for Moi is SVG export :) I use it mainly for 2d stuff at the moment, and it's great for that - but exporting is a real pain!
6925.490 In reply to 6925.489
Hi NightCabbage, I want to work on SVG in the future but it will probably just write the same information that is currently written to PDF format already.
What are you using that would benefit from SVG instead of using PDF ?
6925.491 In reply to 6925.490
Well, I tried using the PDF export, and then importing it into Inkscape (which for the record, I hate lol)... and the results are quite painful.
It breaks up all of the shapes into separate lines - a square would be 4, and with rounded corners it'd be 8... plus then the solids/fills are a giant sheet in the background, as opposed to the actual shapes...
It's a mess LOL
I LOVE Moi3d. It's always been my go-to program for any 2d or 3d design. But the 2d exports are quite painful :(
6925.492 In reply to 6925.491
Hi NightCabbage, it's normal for the shaded filled area to be a giant sheet in the background - the shaded areas are done as a background bitmap those parts are not vector objects.
I tested the PDF export with Affinity Designer and Adobe Illustrator and in both cases a square and a rounded corner square do not come in as individual pieces, they are one curve each. So that seems to be a problem with Inkscape's PDF importer.
SVG output would contain just the same stuff as the PDF export so I'm not sure if it would improve anything for you. I guess maybe it could avoid the curves coming in as individual segments problem if that is a flaw only in their PDF importer.
Maybe if you file a bug report with Inkscape they could improve the PDF importer to behave as other drawing programs do instead of separating everything into individual pieces.
6925.493 In reply to 6925.492
Hi Nightcabbage,
I tested importing a rounded square (exported from MoI as pdf, Top View) into Inkscape 0.92.2 and it does come in as one curve.
What version of Inkscape are you using ?
Michel
6925.494
Having been trying to create a pipeline to hang out in Ipad Pro as long as I can before moving to desktop, and I can say Shapr3D is not as intuitive as MOI3D. I am really not a fan... and in many ways feel there are better programs. It's pretty... Just not as intuitive as your program. I am an Art Director for a pretty big studio... and have a need for a better solution than Shapr3D for fast first level massing. High level architects and engineers can get along with this program (it does the job) - they also have the cash to pay this level of subscription forever. Based on the cost - marketing is definitely trying to connect to a certain level high buyer. Actually Forger App is better for creative output... Damn. It's just that this program is so good that it could take over. I would pay you their subscription over paying them for their program (lol). I realize your just but one and we thank you... Also this program is much bigger than that moment and we all use it to carry our careers forward. I just wish there was an opportunity to have as good of a program as you have built on the Ipad Pro since it's where much is moving... Thanks!
Brandt Peters / Designer: www.brandtpeters.com
6925.495 In reply to 6925.494
Hi Brandt, I'm glad you like MoI but I'm sorry I'm pushed to the limit as it is supporting both Windows and macOS. It just isn't feasible for me to target another platform.
6925.496
need a FFD 2x2x2 or 3x3x3 ... like in 3dsmax
une boite FFD comme dans Max pour tordre des pièces organiques avec un meilleur contrôle que Flow command
histoire de bien faire la nique à Zbrush ;)
6925.497
Hi to all, this topic is long and I apologize but I have not read everything, so I hope not to repeat that, Moi3d 4 now has the ability to import subdivision surfaces as nurbs surfaces, but it would also be nice to have the possibility to choose the type of topology generated, why do I ask this? Because when I use of Subdiv_beta9 I get a grid of edges that I can copy and then generate a new surface with curves reconstructed with Moi3D.
Like this image below
6925.498 In reply to 6925.497
Hi pafurijaz, there is a choice of topology under Options > "SubD import options" > "Patch type". But the current settings there are focused on how extraordinary vertices are handled (vertices with other than 4 edges coming out from them).
It is also additionally possible to control topology by materials though, if you have Options > "SubD import options" > "Use materials" turned on then polygons that belong to different materials in the .obj file will not get merged together into a larger patch.
Or for another possibility you can use Construct > Curve > Iso to extract isocurves out from the large surface.
6925.499 In reply to 6925.498
Thanks I had forgotten the isocurves, excellent and effective solution for my problem, thanks, however the color options may have another option to consider separate surfaces, it could be useful to have sharp edges and separate surfaces between them, such as when you split the surfaces like in this case below. The green one has separated surfaces the other one only different colors but but the same edges, on the left the source file imported inside without touch.
Then could you also consider the possibility of inserting a support for BRep and glTF, import and export?
6925.500 In reply to 6925.499
Hi pafurijaz,
> <...> however the color options may have another option to consider separate surfaces, it could be useful
To get sharp edges you would want to isolate the polygon vertices along those areas rather than have the polys share vertices.
That should be the same as what you would do to set up the .obj file to get sharp edges when importing into a poly modeling program and applying sub-d smoothing to it.
I'm not familiar with either of these formats. What programs support them?
This is the first time I can remember having a request for supporting these file formats. Supporting different file formats tends to take a lot of work and testing so I'm sorry it's not likely to happen soon.
6925.501 In reply to 6925.500
Thanks, for the answers and I understand that you already have too much to do, maybe with the next releases, however BREP geometries are a hybrid way that supports both NURBS and Mesh geometries, and when I create a BRep file from a mesh file with CAD Assistant I can open it with FreeCAD and recognizes surfaces as if it were a nubrs geometry but nothing can be done besides this.
The image show the mesh file into FreeCAD as an regular geometry with nice smoothed edge without the classic grid such as when import the same as a mesh below
normal import
About B-Rep https://www.opencascade.com/doc/occt-7.4.0/overview/html/occt_user_guides__brep_wp.html
And for info about glTF here https://www.khronos.org/gltf/
Thanks and greetings.
Paolo ;)
EDITED: 4 Nov 2021 by PAFURIJAZ
6925.502 In reply to 6925.501
Hi Paolo, doesn't FreeCAD support opening STEP (.stp/.step) format files? You should be able to transfer NURBS surfaces between MoI and FreeCAD using STEP format.
Could you clarify what advantage there would be to using .brep format for the transfer instead of STEP format?
It appears to only support polygon mesh geometry? It looks like there are various converters available to convert from OBJ to glTF format, like here's one example:
https://github.com/CesiumGS/obj2gltf
Sorry currently I wouldn't expect to support either of these from MoI directly. The amount of work to the amount of benefit ratio is not good since you can just use other already existing methods for Freecad transfer, and other already existing converters for glTF.
6925.503 In reply to 6925.502
Thanks for you time, and the main idea come in mind because the Brep handle both geometry Nurbs and mesh, and the whole idea is was take the boundary info from that to do the conversion taking into account the boundary of surfaces, I know you have other priority before that, and I hope more surprise before final release, no mind anyway, I made several test with Moi3d and it has what I deserve, is a very nice application.
6925.504 In reply to 6925.503
Hi Paolo,
Sorry, I'm not understanding this part. Do you mean something like the .Brep file would contain both a mesh version and a NURBS version of the same object?
And that would be something you would create in FreeCAD and then send into MoI for conversion?
But would the mesh be a sub-d control cage mesh or just a rendering mesh made up of triangles only?
If it's a triangle render mesh and there is no sub-d control cage mesh then how would the sub-d converter find a sub-d control cage for the conversion?
And if there is a NURBS version of the object already in the file then why not just transfer the NURBS version over itself, why would there be any polygon to NURBS conversion needed?
6925.505 In reply to 6925.504
Mine are more purposeful and hopeful, but I don't know the implicit issues and if it's possible. However the B-Rep file can contain Mesh and Nurbs geometries and not both of the same, however I create the files with CAD Assistant but they are still Mesh.
Thanks very much for answering
6925.506 In reply to 6925.505
Hi Paolo, but what is the goal with using the .brep format file - are you trying to get a better transfer from MoI into FreeCAD?
Are you starting out with a polygon model and you want to convert it into a NURBS model?
6925.507 In reply to 6925.506
Yeah the main goal is converting mesh geometry into NURBS, but I found new ways with Moi3D, but the mesh modelling was made having in mind the Moi behaviors on conversion but is also a good way to work with subdivision surfaces, Now I work modeling the base mesh in Blender and the then I rebuild when was is necessary the surfaces into Moi3D, and I get a very clean surfaces. And now Blender open the most file made with Rhino or MoI with an experimental build and manage Nurbs
Below an hull created in Blender then converted to NURBS with Moi and imported as NURBS inside Blender, with that workflow I can have awesome nurbs inside Blender no more mesh..
6925.508
Hello pafurijaz -
This Blender (polygons) to Moi (nurbs from subdivisions) and back to Blender (imported nurbs) path is very interesting.
What is the exact link or release number of the Blender build you used ? And, would you mind sharing an example .blend of a part ?
EDITED: 5 Mar 2020 by PIOR_O
Show messages:  1-8  …  429-448  449-468  469-488  489-508  509-528  529-548  549-568  569-575
