V4 Wish List
 1-14  …  435-454  455-474  475-494  495-514  515-534  …  575
6925.475 In reply to 6925.474
Hi eric, it's still on my list. They will likely be fairly rudimentary to begin with though.
6925.476 In reply to 6925.475
Hi Michael ...
Glad its still on the list. Switching back and forth to Rhino is kind of painful.
I'm using MoI less and less ... I'd much rather it was more.
cheers,
eric
6925.477
It would be desirable IMHO to have a means for defining the minimal curve on a surface (similar to rhino's geodesic spline). Also known as Plank Lines, (referencing timber boat hull construction) it is the shortest path between 2 points on a surface which if used to sweep a band over base surface results in a strip that is tangential to that surface over its full length that could be unrolled to a straight strip. This could simply be achieve with UnwrapCurve script of the original rail curve, since long edges are straight & parallel.
Below is an image of traditional hat fabricated from bamboo strips analogous to this technique.
No doubt the maths is quite complex, and perhaps not justifiable ATM.
(https://www.maplesoft.com/applications/view.aspx?sid=34940&view=html)
However if this is something that you have been considering, it could be accommodated in the tool pallet as an option under Contract/Curve/Project as a projection mode menu option "Min. Path". Though a stand alone script would suffice.
I combed through the forum to see if this had been previously discussed and can find no earlier reference. My apologies if you have already answered similar request.
Have a great weekend
EDITED: 5 Oct 2018 by JFH
6925.478 In reply to 6925.477
Hi James, unfortunately the geometry library that MoI currently uses does not have any functionality in it for generating that kind of curve. So it's not a matter of just hooking something up, it would require a lot of effort to make that currently.
Message 6925.479 deleted 10 Oct 2018 by MICHAEL GIBSON
Message 6925.480 deleted 10 Oct 2018 by MICHAEL GIBSON
If someone is wondering about the deleted messages, they seem to be spam "warm up" messages where someone is reposting a previous message that has been translated from English to some other language and back to English again. I'm not entirely sure why someone would do that, I think it's something like some forums don't let you post links until you've posted some regular messages first.
6925.482 In reply to 6925.481
OK. Got it. Thanks.
I also thing that it was a spam.
Kill it!
6925.483
Hi. I have a small wish- :)
It would be great to have a 'Shift+Left Click' option checkbox available somewhere in the Options as an alternative selection mode. With this option checked, the user would need to hold down the shift key in order to add to the current selection. Left clicking without shift would select but clear the previous selection.
I've gotten into trouble quite a few times now when I've tried to do something and later discovered I had more objects selected than I realised (I'm used to left-clicking something and clearing whatever was previously selected).
Hopefully this wouldn't be too much trouble, and would be a very welcome feature.
Really enjoying MoI, btw. And the ability to bring in poly objects in the V4 beta has been extremely helpful.
Thanks very much!
EDITED: 5 Nov 2018 by EKAR
6925.484
Just found this thread.
Would appreciate in V4:
- Fillets and chamfers improved. So in case they should overlap they don't 'crash'.
- File type import/export expansion. Mostly OBJ and STL.
- custom commands and scripts. Could be made so user can place own buttons for each inline script, or command.
- ability to create lithophanes. Something like hightmap script from Max.
- set object partialy visible (opaque)
Surely it's up to developers to decide which ones are requested most and what kind of programming is needed for implementation.
I'm patient :)
EDITED: 5 Nov 2018 by MR_JURAJ
6925.485
I think the main thing I would like to see is a smarter selection system in general, pattern select, edge loop select, etc. There is an edge loop selection script I found but it's not very smart and something more like how Modo or Blender works would be quite nice.
Another feature would be a modifier stack system like in Blender or 3DsMax. Ideally a node based system. This is probably a v5 feature request though but having a more organized way to do non-destructive operations would be great.
Other than that I really enjoy using Moi, I can't think of a nurbs tool I would want to add to it but I'm still getting used to it.
- actually one thing I can think of is a custom pie menu like in Maya or Blender so I can switch between some tools on my tablet a bit quicker.
EDITED: 9 Nov 2018 by FOXFIRE
6925.486
Would it be possible to include in V4 a Styles/sub-directory for a spectral range of colours for colorisation by node editor?
As Karsten validly states in reference to setStyle node that: "a RGB input would create a lot of styles or you have to create and delete again and again".
see http://moi3d.com/forum/index.php?webtag=MOI&msg=7777.1272
I don't think however, that this deletion and creation, presents a problem (in terms of extraneous complexity to the user experience) if these new temporary styles were in a separate list (generally hidden from user).*
Please let me know your thoughts
*Indeed complexity could be further reduced with inclusion of a "levels" input on setStyles node to determine the number of steps in spectral range (so in some cases it may only be a handful of colours).
EDITED: 16 Nov 2018 by JFH
6925.487 In reply to 6925.486
Hi James, in the future I do want to add in folders that you could use to organize styles, so you could collapse the folder and have a chunk of them stay out of the way. Would that be the kind of thing that would help? But sorry I'm not expecting to have that done for V4 though.
6925.488 In reply to 6925.487
>> in the future I do want to add in folders that you could use to organize styles, so you could collapse the folder and have a chunk of them stay out of the way. Would that be the kind of thing that would help? <<
Yes that's exactly what I'm thinking: a dedicated folder (perhaps created on the fly by node editor) where generated styles could be written & overwritten without affecting the default styles used to differentiate model parts.
Thanks for getting back to me
6925.489
My number 1 wishlist item for Moi is SVG export :) I use it mainly for 2d stuff at the moment, and it's great for that - but exporting is a real pain!
6925.490 In reply to 6925.489
Hi NightCabbage, I want to work on SVG in the future but it will probably just write the same information that is currently written to PDF format already.
What are you using that would benefit from SVG instead of using PDF ?
6925.491 In reply to 6925.490
Well, I tried using the PDF export, and then importing it into Inkscape (which for the record, I hate lol)... and the results are quite painful.
It breaks up all of the shapes into separate lines - a square would be 4, and with rounded corners it'd be 8... plus then the solids/fills are a giant sheet in the background, as opposed to the actual shapes...
It's a mess LOL
I LOVE Moi3d. It's always been my go-to program for any 2d or 3d design. But the 2d exports are quite painful :(
6925.492 In reply to 6925.491
Hi NightCabbage, it's normal for the shaded filled area to be a giant sheet in the background - the shaded areas are done as a background bitmap those parts are not vector objects.
I tested the PDF export with Affinity Designer and Adobe Illustrator and in both cases a square and a rounded corner square do not come in as individual pieces, they are one curve each. So that seems to be a problem with Inkscape's PDF importer.
SVG output would contain just the same stuff as the PDF export so I'm not sure if it would improve anything for you. I guess maybe it could avoid the curves coming in as individual segments problem if that is a flaw only in their PDF importer.
Maybe if you file a bug report with Inkscape they could improve the PDF importer to behave as other drawing programs do instead of separating everything into individual pieces.
6925.493 In reply to 6925.492
Hi Nightcabbage,
I tested importing a rounded square (exported from MoI as pdf, Top View) into Inkscape 0.92.2 and it does come in as one curve.
What version of Inkscape are you using ?
Michel
6925.494
Having been trying to create a pipeline to hang out in Ipad Pro as long as I can before moving to desktop, and I can say Shapr3D is not as intuitive as MOI3D. I am really not a fan... and in many ways feel there are better programs. It's pretty... Just not as intuitive as your program. I am an Art Director for a pretty big studio... and have a need for a better solution than Shapr3D for fast first level massing. High level architects and engineers can get along with this program (it does the job) - they also have the cash to pay this level of subscription forever. Based on the cost - marketing is definitely trying to connect to a certain level high buyer. Actually Forger App is better for creative output... Damn. It's just that this program is so good that it could take over. I would pay you their subscription over paying them for their program (lol). I realize your just but one and we thank you... Also this program is much bigger than that moment and we all use it to carry our careers forward. I just wish there was an opportunity to have as good of a program as you have built on the Ipad Pro since it's where much is moving... Thanks!
Brandt Peters / Designer: www.brandtpeters.com
Show messages:  1-14  …  415-434  435-454  455-474  475-494  495-514  515-534  535-554  …  575
