V4 Wish List
 1-11  …  192-211  212-231  232-251  252-271  272-291  …  572-575
6925.232 In reply to 6925.60
Just to things:
- 64 bit support, so I can really load big files.
- Block / Instance support, as this is essential in my work.. however I wonder if instances exist in output formats like OBJ (They exist in LWO).
6925.233 In reply to 6925.232
<<"64 bits"
it's for that V4 is created! :)
6925.234 In reply to 6925.232
Hi Robert, yes 64-bit is the main goal of the rewrite for v4, so that will be in the first beta release.
Instancing is high on my radar to work on during the v4 beta period, but it is a big area overall especially including data transfer like you mention. OBJ format does not have any concept of instancing in it. LWO format in its original form I don't think has it either actually, I can't find it mentioned here: http://static.lightwave3d.com/sdk/2015/html/filefmts/lwo2.html it's possible that it's implemented as an extension in it that's not part of the old public spec though. Trying to deal with undocumented types of data can be very time consuming.
It might be possible for FBX and SKP format for current export types. It could be a good reason to implement some additional formats like Collada.
Something that's such a large area isn't too likely to get implemented all in one single go though, it's more likely that it will come in stages with a focus on the UI for working with the instancing in MoI only at first before trying to tackle import/export to other formats.
6925.235 In reply to 6925.231
While I have not personally tested it, seemingly whether by ADO or OLE DB, the Database Connection can be hosted by the JavaScript interpreter.
https://www.google.com/#q=ole+db+javascript
https://www.google.com/#q=connect+html+page+to+sql+server+database+using+javascript
Does anyone on the forum have direct experience with this?
Maybe your V4 could expose the objects' unique UUID and provide a method that uses it as a parameter to select the object.
Because SQL Server has a hierarchy data type, grouping could be managed externally.
Of course SQL naturally treats all data as Boolean sets.
I would be willing to help with the SQL code, i.e. Stored Procedures, etc..
-- MindSet
6925.236 In reply to 6925.235
Hi Mindset,
This is actually possible in v3 currently - in script there's an .id property on objects that returns the object's UUID in string form.
The reverse way to look up an object given the UUID is provided by the findObject() method on moi.geometryDatabase, it's used like this:
var obj = moi.geometryDatabase.findObject( id );
6925.237 In reply to 6925.236
Yea Michael,
I'll give it a try and report back!!
-- MindSet
Hi Michael.
What's the compatibility degree of the upcoming V4 with the current latest V3 ?
More in depth :
1) Scripts.
The new API core (if there is a new one) will be backward compatible with the current API ?
All the Scripts written for V3 will continue to work properly on V4 ?
2) .3dm file format
Moi V4 will use by default the Rhino 5 format instead of Rhino 4 ?
3) Html files.
The new V4 will accept all custom html files used to customize V3's UI ?
4) Shortcuts
Can I use with V4 all the hotkey setup that I currently use for V3 ?
Thanks a lot and have a nice day.
6925.240 In reply to 6925.239
Hi Marco, it is intended that MoI v4 will have a high amount of compatibility with v3. The main thing that you'll have to watch out for is UI customizations. The v4 UI can be customized similarly as v3 but the structure of the UI is slightly different since v3 used an older version of the WebKit flexbox for arranging things and v4 uses the newer standardized flexbox. It's only pretty slight differences but you'll generally need to merge any UI customizations into the new v4 structure rather than just copying the entire v3 .htm UI files (like SidePane.htm and CommandBar.htm) over directly.
For your specific points:
> 1) Scripts.
There is a new implementation for the internal bridging between C++ code and script, but it presents all the same properties and object model as v3 so in general V3 scripts should run in V4. There may be some differences from in how exceptions are thrown for errors in a couple of spots and so it's possible that a few scripts may need slight adjustments to a couple of lines of code (or I'll tune up the engine behavior to make it compatible) but I think that will be pretty rare.
The threading model for scripts is different in v4, in v4 command scripts will run on the main thread rather than running in moi_commandprocessor.exe and doing interprocess communication. This should be for the most part be transparent to script but also may be a source of slight differences for how exceptions are thrown.
> 2) .3dm file format
No, this is the same as MoI v3. It will save to Rhino 5 format if you have opened a Rhino 5 .3dm file. If you have made a new file in MoI then it's saved as a Rhino 4 file.
> 3) Html files.
This is the area where you'll have to watch out - the V4 html files are slightly different from v3 and so you can't just copy an entire customized v3 UI in place of the v4 UI files, you'll need to merge your changes into the new v4 structure. The same thing applied to the transition from V2 to V3 and will probably continue to be the case between major versions until I'm able to make it more modularized.
> 4) Shortcuts
Yup, this should be directly compatible. Moi v4 will use the same moi.ini file as v3 and so your shortcuts should just be there and work the same. In v4 the shortcut keys section of the Options dialog has been tuned up so that when you add in a new shortcut key you define it by pressing the actual key combo instead of typing in text like "Ctrl+A".
6925.241 In reply to 6925.240
Hi Michael.
Perfect! Thank you very much for these such detailed info.
I stay tuned. Have a nice day.
6925.242
Unless I'm missing this feature or procedure somewhere. ;-)
6925.243 In reply to 6925.242
Hi Mike, I just recently made a Distribute plug-in to do that, please give this a try:
http://moi3d.com/forum/index.php?webtag=MOI&msg=8503.13
6925.244 In reply to 6925.243
Thank you Michael!
This option was so needed. :-)
6925.245
Michael,
Once again sincerest Thank You for your quietly cultivated jewel of a software.
I haven't waded through the waste deep list of demands on your time for a while but after doing some serious 3 fingered rotating on a recent train trip I was yearning for a saved camera angle option to pop between critical angles...I know someone must have said it, but nontheless.
Back to yelling insanely at Fusion users to drop-the-zero-and-get-with-the-MoI-hero for me,
- Rich
6925.246 In reply to 6925.245
Hi Rich, it will only save and restore views within a single session but maybe the save/restore view scripts from here would be useful for you now:
http://moi3d.com/forum/index.php?webtag=MOI&msg=2891.7
6925.247
Brill thanks Michael! [insert feature into v4 here]
- Rich
6925.248
Didn't read the entire thread but I'd like to ask for as powerful and or advanced drawing tools as possible. I couldn't tell you what exactly that is but anything that would lead to accuracy and productivity enhancements (removing laborious tasks). Love the program!
6925.249 In reply to 6925.231
Hi when will you publish moi3d v4? Do you have a release date
6925.250 In reply to 6925.249
Hi ercan2423, sorry I don't know a release date quite yet. I'm still in the process right now of working on the viewport display part. Once that is functioning well I will release the first v4 beta release and that will start the beta test process. Then there will be a beta test period for a while after that, anything like 6 to 12 months, before the final release will be ready.
So not too much longer for the first v4 beta release but the final v4 release is still a ways out.
6925.251 In reply to 6925.250
Thank you for your information. v4 Curiously wait...
Show messages:  1-11  …  172-191  192-211  212-231  232-251  252-271  272-291  292-311  …  572-575
