V4 Wish List
 1-12  …  73-92  93-112  113-132  133-152  153-172  …  573-575
6925.113
Moi is my swiss army knife in 3D modelling. Quick, fast and obvious.
During the years only one situation was frustrating when I cut doors on the car body. Every time I changed the shape I had to cut the door again and again. A basic history based boolean would be nice. Similar than in Archicad. But I am still very satisfied next to Rhino, Viacad, Revit and Moi.
6925.114 In reply to 6925.111
@Marco - yes that's certainly correct that MoI is not focused on being a parametric modeler currently, but having said that it is certainly a valid wish for future versions. The tricky part is that often times in parametric modelers the process of defining the "recipe" for the model can dominate the workflow and I would like a history editing function that would be an optional thing instead. I have some ideas for this that I'd like to explore in the future but it will definitely be a lot of work involved.
@Max - I'm not really that fond of polls, I don't really get a good sense of what someone needs other than their top choice, and it's too easy for the top choice to be something requiring a massive effort that I won't be able to do in the current release. I'd recommend instead posting your top 5 wishes, when I see a lot of users posting similar lists then that helps give them more weight, and hopefully it's more likely that some of them would not be in the high development time category.
The best way to get your wish bumped up to high priority is to propose one that fits within the existing UI by extending some existing function in some way without needing to have a whole lot of new UI developed for it particularly at the top level.
6925.115 In reply to 6925.114
Hi Micheal and good morning.
Thank you very much for your detailed and clear reply!
> "...I would like a history editing function that would be an optional thing instead.
I have some ideas for this that I'd like to explore in the future but it will definitely be a lot of work involved."
I totally agree with you that a good thing it would be to give the history feature as an optional and not invasive tool.
It's a very good news to hear from you that you're thinking about something regarding some sort of history for Moi.
It's the first time I hear it.
Thanks!
> "... I'd recommend instead posting your top 5 wishes..."
Hmmmm....it's a very hard work :) As you saw, my wishlist it's not so compact...I'm sorry.
> "The best way to get your wish bumped up to high priority is to propose one that fits within the existing UI by extending some existing function in some way without needing to have a whole lot of new UI developed for it particularly at the top level. "
Considering that, frankly speaking which point of my requests do you consider not feasible in the immediate future ?
1) Dimensioning, instancing, and grouping are all absolutely "wanted dead or alive"
2) At least some basic "surface-continuity" tools like "Zebra stripes" and "Environement Map" like Rhino
3) G3 and G4 continuity for blend tool !! At least G3.
4) Command for ContinueCurve and Merge curve (VERY IMPORTANT for me)
5) A revisited API interface with a complete access to Knot points, control points, curvature data.
6) It would be great if it were possible have these Rhino commands : MatchSrf, SelUV, MoveUVN, Cage and CageEdit
7) Better viewport rendering : ghosted mode, better anti-aliasing, line style for the edges
8) Display of IsoCurves
9) Export to AI and PDF with more customizable line styles.
And...newer CAD Kernel, for more robust Solid operations (Shelling, Offsetting, Filleting).
Thank you very much for your support and have a nice day!
6925.116 In reply to 6925.115
Hi Marco, well that's an awfully long list that you've got there, v4 would take a really long time to come out if I tried to implement all those things in it. I'd hope to get at least some of those things but I have to prioritize and so I'd have to say things related to surfacing continuity, display modes, and surface control point editing are areas that are quite a bit more specialized in use than some of the other things.
The main goal for MoI is to try and make it quick and easy to build simple objects. Many of the tools you are asking for there such as G4 continuity for example are not really in line with that, so it's hard to give them very high priority. Maybe if I understood more details about how having a G4 blend instead of a G2 blend would solve a particular problem for you that could change things though.
I don't in general like to comment too much on wishlist posts because I don't really want to discourage others from posting about what they really want, and my priorities can change a lot if I see a pattern in many people asking for the same stuff. I will tend to comment though if someone posts just one wish saying they hope it will be in the next version but it's either not a good fit or would require a whole lot of work and so isn't too likely anytime soon - I just want to let them know that if some other program already handles what they are asking for they are probably better off using that other program for their work currently (so they can solve their problem and therefore make progress with their productivity) rather than trying to use MoI for something that it's not really designed to do.
One thing to keep in mind is that it's not really a goal for MoI to try and do every single task that's in every existing CAD program all added together. The main goal is more something like trying to take some of the most convenient areas of CAD and make them easier to access both in workflow, UI, and in lower learning curve. But these are rather fragile things and they can pretty easily be lost just simply by "feature bloat" of accumulating a large number of features that are not frequently used. So any new feature kind of starts out with a negative weight to it, and it gains in priority if it would make more people's jobs easier to do in some way. Also my time is fundamentally limited, so each feature comes at a cost - I mean if I'm working on one area it implicitly means some other feature is not getting worked on at that same time. So it tends to be good for me to work on areas that deliver the most "bang for the buck".
6925.117 In reply to 6925.116
Michael I want to thank you for your quick and honest reply! Thanks a lot.
> " I mean if I'm working on one area it implicitly means some other feature is not getting worked on at that same time. So it tends to be good for me to work on areas that deliver the most "bang for the buck"."
I totally understand you about this point. As i told you some times ago I'm a (little) ISV and so I fully understand the problems regarding the limited time :)
Let me explain better...
Some of the features I'm asking for, are relative to the fact that I'm using almost exclusively Moi for my nurbs modelling,
while at the same time I also own RhinoV5 and V6 WIP.
But when I bought Rhino, I bought it only for some of its particular commands
(surface continuity, G3 G4 blend, UV point editing, cage, and some other stuff).
So it would be really great for me if Moi could give us these 4-5 features that Rhino has in order to get rid of Rhino,
because I don't love its UI and workflow and I see that in McNell they don't have any intention to change this thing.
I asked you about (at least) G3 blend because IMHO G2 it's not sufficient in some case for a good surface continuity.
Anyway, it's not my intention to bore you with tedious and long discourses,
so I'm confident that you will get all ours wish list and will do the best job!
Thanks for all and have a nice day Michael.
Ciao!
6925.118 In reply to 6925.117
Hi Marco, no problem!
> Rhino has in order to get rid of Rhino, because I don't love its UI and workflow and
I'm sorry but it's just not practical for me to make it a focus point on replicating specialized Rhino tools into MoI. The fundamental problem with a goal like that is that different people will have a different set of 4-5 features and all combined together you're then talking about an awful lot of features to add in.
It's really more the opposite in fact - because Rhino already has those specific features you need to use, and you can easily work with MoI and Rhino together, that actually makes it all the less of a priority for me to replicate them because you can solve your problem of accessing those features already at the current moment by using MoI and Rhino in combination with each other.
At this time it's still more of a priority for me to work on much more basic things than that in MoI. At some point in the future it could be possible for some of these fancier things to trickle in, but it just doesn't make much sense to focus my effort on G3 surface blends when I still don't have dimensions in MoI as of yet. There's still quite a lot of work left to do in widely used basic functions like that.
Do you have any examples you could send to me? With G2 reflection lines are already smooth, G3 and G4 are getting into very esoteric properties that are difficult to perceive.
Thanks, - Michael
6925.119 In reply to 6925.118
Ciao Michael.
Thank you very much Michael for your additional clarifications. Much appreciated!
> "..The fundamental problem with a goal like that is that different people will have a different set of 4-5 features and all combined together you're then talking about an awful lot of features to add in."
Aaaaahhhh LOL LOL :)
I apologize...you're totally right!! Customers' desires are almost like the wind....supremely difficult to catch!!
> "It's really more the opposite in fact - because Rhino already has those specific features..."
Ok. So the brutal truth for me it's that I have to surrender to use Rhino for that things :)
(Luckily, the are funny things like Fusion360...)
> "Do you have any examples you could send to me? With G2 reflection lines are already smooth, G3 and G4 are getting into very esoteric properties that are difficult to perceive."
ASAP I will post some example of what I want to say regarding G3 vs G2.
Thanks again and have a nice day.
6925.120
Hello,
My whish list:
1. Groups
2. Instancing
3. Dimensions (improve Max's Dimensions)
4. Ghost mode view (semi-transparent objects)
5. Joint mechanism (don't know if this could fit or make sense in Moi's)
Thanks.
Carlos
6925.121
Hi Michael ...
My priority remains: dimensioning and Text that is not made up of 3d solids.
Yes, I have Rhino and it is not a big chore to switch back and forth but I would rather not have to.
2nd on my list are line types.
Printing would be nice.
Thank you for MoI.
cheers,
eric
6925.122
So my biggest wish is 64-bit, a client sent me a huge data sets(I talking entire buildings...)! Also if the viewport can handle huge data would be nice, being able to move around and work on huge data is a must once you go 64-bit. Fusion360 still struggles in the latter area.
EDITED: 20 Nov 2016 by SONKIM
6925.123
Michael, could you please add a "Create cool model" button to MoI V4. I'd appreciate that.
Thanks in advance,
— Metin
metinseven.com — 3D (print) models • animation • characters • icons • illustration • infographics • visualization
6925.124 In reply to 6925.123
@ Metin
Try Shift + Ctrl + Alt + Click on the Icon Options (Bottom right screen)
6925.125
Hello,
while playing with the API, I try to use the freehand sketch tool, but using it, allways gives no satisfactory result. It's so final. So I tried to improve the behavior, but its very difficult to implement in JS. Nevertheless I want to make a proposal for maybe v4 or v5. The sketch curve isn't finished until I make a gesture or until a timer runs out.
If not that, a G2-Patch tool for 3-4 sided gaps in joined surfaces.
Have a nice day
Karsten
EDITED: 18 Dec 2017 by KMRQUS
6925.126 In reply to 6925.124
Frenchy: :D
— Metin
6925.127 In reply to 6925.125
Karsten, good suggestion, to be able to correct parts of a freehand curve. That'd be great.
— Metin
6925.128 In reply to 6925.127
Hello Metin,
yes - my problem is, that I have a pen-tablet, but I never use the Sketch, becaus e- after I've made the Sketch, I always make a rebuild, switch on the control points and move them around:-(
I've written a script for sketch/stroke manipulation, but the result is still unsatisfying (as shown)
Anyway it would a cool feature for tablet users and would build a bridge to a more natural workflow on tablets.
Have a nice day
Karsten
6925.129 In reply to 6925.128
Hi Karsten, I've thought before about trying to make a curve shaping tool that worked sort of like an airbrush where you could apply multiple airbrush strokes and then I'd work on fitting a curve through the densest region of it. Then maybe you could alter it by erasing the edges of some airbrush areas or applying more airbrush strokes on top of other areas.
Unfortunately it will require a lot of very time consuming experimental work to make that happen so I'm not likely to be able to get to it very soon.
Right now if you want more control than what the current sketch can do, I'd recommend drawing with control points instead.
6925.130 In reply to 6925.129
Hello Michael,
I'm sure you've already thought about it. And I agree with you, that you have to do some more important things at the moment, but I believe it would fit perfectly to Moi's intuitive concept.
Many thanks
and have a nice day
Karsten
6925.131
Hello Michael,
Might it be convenient to introduce a feature to manage a user-defined list of observation vantages for the 3D viewport?
It may be useful, between edits, to have the ability to reset the perspective view to that of a prior screenshot.
MOI is the best software experience.
-- Mindset
6925.132 In reply to 6925.131
Hi Mindset, yes that's often times called a "named view" or "saved view" and it is something I want to add. I've been thinking about making a new section in the Scene Browser that could hold some "lists of things" like this, such as saved views, cplanes, and maybe background bitmaps should go under there as well.
Show messages:  1-12  …  53-72  73-92  93-112  113-132  133-152  153-172  173-192  …  573-575
