extracting curves?
All  1  2-5
692.2 In reply to 692.1
Hi Moka - you mean edge curves of a surface or solid?
Select the edge (to select all edges, first select one and then use Select / Select All) and use Edit / Copy and Edit / Paste to duplicate them.
Also if you want to grab a quick copy of a single one, select it and use ctrl+drag to drag off a copy.
692.3 In reply to 692.1
Edit / Join command also works if you select the edges that makes a chain... -Petr
692.4
thanks, - did not think it would be that easy
You can also draw a line in front of your object, project it and extract the result :)
Show messages: All  1  2-5
