Brake caliper modelling
 1-2  3-22  23-40
6900.3 In reply to 6900.2
Thank you very much Michael!
I'll send to you immediately the 3dm file to your mail.
6900.4 In reply to 6900.3
Ciao!
here some of the upgrades that i've done today ;)
I did some particular on the upper side....
Then i did a big fillet by sweep on the lower side then i've added the two fixing holes and to the end i added two reinforcing rib.
And then i added a lot of fillets to the caliper body, two new parts (a clip and a pin) and i did the pistons holes.
Amazing work in progress!
This one ?
6900.6 In reply to 6900.5
Ciao Pilou!
Thank you very much
Yes...it should be that one :)
My goal is to take an idea from that caliper...not to reproduce 100% identical :)
This is my third model with Moi so it still difficult to me to reproduce everything because i'm learning the program and i'm fighting with fillet....but thanks to this fight...i'm learning the right approach to draw with Moi3d and i'm learning something new...and i'm happy of it :)
My goal is to produce the entire caliper....and maybe the brake disc too...entirely on Moi...without using any other 3d program for fillet....i want to use only Moi3d :)
I often do automotive rendering and often the 3d model are very accurated and nice about the exterior lines but sometimes the brake caliper and disc are really bad and of poor quality....so i'd love to have my 3d brake system to use it on my 3d rendering :) ....and Moi3d is helping me to realize it :)
Sorry for my english
Arian
6900.7
Nice modelling for someone less than a week into Moi - You're doing great buddy, keep it coming and don't apologise for your english, your point is coming across just fine.
Martin Spencer-Ford
6900.8 In reply to 6900.7
Thank you very much Martin! :) about EVERYTHING :D
Arian
6900.9 In reply to 6900.8
Today i was home from work so this morning i did some upgrade to this work...
I did the caliper pistons:
After that i did the rotor seat on the caliper ( don't know the correct name in english :( :( :( ) and i did its fillets!
Then, i did the superior clip and i started to fight with some fillets that give to me some problem...
I wasn't able to do the fillets with fillet command so i helped my self with sweep and boolean actions...
and....it worked! :)
This is the actual caliper until now...
..this afternoon i'll work another little...then i'll try to do pads and rotors too :)
Ciao
Arian
6900.10 In reply to 6900.9
Coming along nicely Arian, nice trick with the boolean ops to get the fillet you want ;)
Martin Spencer-Ford
6900.11 In reply to 6900.10
Thank you Martin :D
Here we are...another upgrade...
I did the oil holes....
Then i did the screws to fix the clip and the superior little frame....
and also the clip to close the oil holes.
Then I proceeded with the creation of the seat for the pads stopper on the lower side of the caliper....
....and i do the fillet on the lower side of the caliper.
then... in prevision to do some animation with this model i wanted to add some details so i did the thread on the screws....
and the last thing...i did the 4 pads stopper and their fixing screws...
The caliper should be complete now...and this is how it looks now...
Tomorrow I'll start with pads and rotor :)
EDITED: 10 Sep 2014 by ARIANSHAMIL
6900.12 In reply to 6900.11
ok...i've just reuploaded the images...hope everything is ok now...
Ciao & good night
Arian
6900.13
i REadded the images.....hope now they're ok....
Arian DESIGN
www.arianshamil.com
6900.14 In reply to 6900.13
Well Done!
6900.15 In reply to 6900.14
Thank you David!
Hope to post soon some other progress...
I want to complete the brake system, then rendering it and, with some times....do an animation with that :)
Arian DESIGN
www.arianshamil.com
A very long page! :)
www.arianshamil.com
6900.17 In reply to 6900.16
Thank you
I hope to add other images soon....
Arian DESIGN
www.arianshamil.com
6900.18 In reply to 6900.17
It's coming together very well Arian!
6900.19
Thank you very much Michael! :)
Today i had very little time so i did just a small and fast upgrade....the brake pads...
Arian DESIGN
www.arianshamil.com
6900.20 In reply to 6900.19
another little update...sorry for the slow progress on last days but I'm really busy :(
Anyway....Rotor (carbo-ceramic rotor type) :)
Next steps will be:
Flange, fixing then rendering of all the kit :)
Arian DESIGN
www.arianshamil.com
6900.21 In reply to 6900.20
Looking good Ari, keep it coming :)
Martin Spencer-Ford
6900.22 In reply to 6900.21
Hope to post something new tomorrow :)
Arian DESIGN
www.arianshamil.com
Show messages:  1-2  3-22  23-40
