File Saving
All  1-5  6-11
690.6 In reply to 690.5
Hi Brian, it is normal that those curves saved directly would not work (since there is no surface there to mesh), but after you do a loft it is supposed to work. It works fine over here...
Make sure when you do the loft you push the "Done" button to complete the loft.
Other than that I'm not sure what might be going wrong.
Can you try a test with just a sphere? (go to Draw solid / Sphere to just draw one of those).
When you save to an OBJ file, after you close the file dialog where you choose the file name, you are supposed to see a "Meshing options" dialog that lets you choose what density of polygon mesh you want to create.
Do you never see the "Meshing options" dialog? Is it possibly off to the side a little bit or something?
690.7 In reply to 690.6
I worked through all the things you said and the stuff came up as you indicated and I was able to save.
Dont know how I was not getting all those things to show up before though. Thanks.
690.8 In reply to 690.7
Hi Brian, what I suspect was happening was you were doing the loft, and then going to Save before exiting the loft command.
That would cause the Loft command to cancel out, which actually removes the loft. So when you were saving the loft wasn't actually there.
There are several commands that let you change options and stuff like that before they are complete - loft is one like this. For these commands you have to push the "Done" button (or right-click in a viewport or push Enter) to finalize the command before it is all done. Otherwise if you start a different command (including save) before pushing "Done", it is the equivalent of canceling.
I'm glad you are rolling now!
690.9 In reply to 690.8
Welcome to the club Brian, glad to see you over here - It'll be nice to see what you come up with using MOI!
-Will
690.10 In reply to 690.9
Here's a good thread to read when learning MOI:
http://moi3d.com/forum/index.php?webtag=MOI&msg=510.2
Pilou has posted some good stuff thoughout the forum - I believe there's another tut page but I couldn't find the post on that one...
-Will
690.11
Thanks. Think that will keep me going for---5 minutes!!!!
(See you in a months time?)
Show messages: All  1-5  6-11
