Sharp points delete, script request.
All  1-3  4-18
6890.4 In reply to 6890.3
I think no need for filet, it is better to run it separatly becouse some times you need diffrent fillet radius.
6890.5 In reply to 6890.3
Hi Andrei, Max's script works by doing a "select all" and then a copy to the clipboard of the points and then a paste back in of those points. That is indeed a way for a script to access the points without there being a proper script interface, but it's limited in what it can recover, it only gets a big bunch of points and isn't able to access additional information like being able to determine which particular points are actually corner points or not.
Just in general it's difficult to make scripts that do control point manipulation since things are not currently set up to make all the information about the points accessible to a script.
re: #1 - delete the curves, you can modify Max's script to delete the original curves at the end by adding in one additional line right near the end like so (line to add marked with >>>, don't include the >>> characters):
		for ( var i = 0; i < curves.length; ++i ) { curves.item(i).selected = true;}				// âêëþ÷àåì îòáðàòíî âûäåëåíèå èñõîäíûõ êðèâûõ
>>>		g.removeObjects( curves );
DelCorners();
re: #2 - sorry I don't understand this part, do you mean you don't want it to wait for you to change the point selection and just immediately proceed with processing each curve?
re: #3 - adding fillets, this is possible but will unfortunately be fairly time consuming to set up so I'm sorry I will not be able to do that one for you right now.
6890.6 In reply to 6890.5
Thank you!
Yes!
Just want to run script and replace all shar points without any other steps.
6890.7 In reply to 6890.6
Hi Andrei,
> Yes!
Try using the attached version, it has that point picking step removed.
6890.8 In reply to 6890.7
Great Michael, thank you very much!!!
6890.9 In reply to 6890.8
Michael is it possible to make fillet work on multyple curves at the same time?
My Portfolio: www.samardac.com
A lot of my Tutorials!
6890.10 In reply to 6890.9
Hi Andrei,
One difficulty with that is that fillet works in a different way currently if you pick 2 different curves, it does a fillet just between those curves like for example if you have 2 individual separate line segments selected that cross each other.
That fillet between 2 individual lines is the sort of old style AutoCAD type curve fillet method.
6890.11 In reply to 6890.10
It will be nice, to fix it in the future.
6890.12
Some Tips on how to use DelCorners.
http://moi3d.com/forum/index.php?webtag=MOI&msg=6058.43
1
6890.13 In reply to 6890.2
>> currently there is no script interface set up to allow scripts to access the individual edit points of a curve
Hi Michael!
Could you implement this interface in the future versions of MoI?
It will be very powerfull tool for scripting.
Something like this:
curve.getControlPointCount()
curve.getControlPoint(index)
curve.setControlPoint(index, newcoords)
and for surfaces:
surface.getUControlPointCount()
surface.getVControlPointCount()
surface.getControlPoint(U_index, V_index)
surface.setControlPoint(U_index, V_index, newcoords)
6890.14 In reply to 6890.13
Hi Max, yes I do want to add something like that in the future. If you can bring it up again during the v4 development cycle that would be a good time for me to dig into it.
EDITED: 2 Sep 2014 by PILOU
6890.16 In reply to 6890.15
Hi Pilou, for the case you show there, just draw in a new 3 point curve using Draw curve > Freeform > Control points, you'll then have the new segment in the shape you want.
Or another possibility is to use Edit > Separate and then Edit > Join and only join the ending 2 segments together and then run DelCorners on that...
6890.17 In reply to 6890.16
Yes :)
It was just for know! :)
First method is more suitable and easy!
Mine is draw a new "no corner point" near the old corner then kill the corner point and move the new on the old! :)
French version :) http://moiscript.weebly.com/delcorners.html
English one
Show messages: All  1-3  4-18
