very close
 1-18  19-38  39-58  59-67
6875.59 In reply to 6875.56
Hey Michael,
Thanks for putting the new trial link up! I tried it today through Wine on Linux Mint 17. It seems to work fine, but the fonts look bad; they are very thick and hard to read. See the attached image (view it full sized -- the scaled-down version of the image masks the problem a little bit, I think). I started with a clean wineprefix and didn't use any winetricks. At first I thought it might be a video problem, but the same thing happens on multiple machines with different video drivers, and I didn't have any such problems with MOI 2. Any ideas?
Dan
Size: 259.1 KB, Downloaded: 80 times, Dimensions: 1226x796px
6875.60 In reply to 6875.58
Hi David,
> Hi , I ordered MoI V2 one month ago , how do I get the free V3 upgrade ?
I'll be setting up a web page where you'll be able to put in your v2 license key and then get the v3 upgrade if you've ordered v2 recently like you have.
I don't have it set up quite yet though, it will take me a few more days yet or possibly a week before I will have it set up.
In the meantime you can get the v3 beta version from here: http://moi3d.com/beta.htm - it's pretty much the same software as the final v3 version except that it will expire in a couple of months. But the beta version will allow you to use v3 now with your v2 license until I get the upgrade mechanism worked out.
6875.61 In reply to 6875.59
Hi Dan,
Hmm, those fonts do look odd - sort of looks like antialiasing is not working at all.
What version of Wine are you using? The last configuration that I tested with on Linux Mint was this:
LinuxMint 16 (32 bit)
Video driver: Nouveau version 1:1.0.9-2ubuntu1
Wine: wine-1.4.1
If you're using a wine version newer than that, there is probably some bug that was accidentally introduced in Wine that is messing up the font handling.
So you may be able to solve the problem if you set up Wine version 1.4.1 for MoI to use. It's possible to do that but I think you have to build Wine yourself, not get it from a pre built package (since those want to go into one central location). See here for some instructions:
http://wiki.winehq.org/FAQ#head-5d2fd5010318b5facd3ebf67930d1259e67c465f
http://forum.winehq.org/viewtopic.php?t=9630
http://forum.winehq.org/viewtopic.php?t=10041
If you try setting up a build of Wine 1.4.1 and make it go into its own separate prefix like ~/.wine-1.4.1 that might work.
There tends to be quite a bit of churn in Wine and it's not unusual for especially cosmetic bugs to pop up in it and then get solved in new releases after a bit.
6875.62 In reply to 6875.61
Thanks Michael,
I'm using wine-1.6.2. Maybe I'll give 1.4 a try, or just hope a later update fixes the problem. It's not unusable anyway, just ugly. It seems odd to me that MoI 2 never had that problem, but then again I haven't run it in awhile and maybe there was an update to Wine since the last time I tried.
Dan
6875.63 In reply to 6875.62
Hi Dan, the whole UI for MoI changed very substantially from v2 to v3 - in v2 all the text is being drawn by the mshtml.dll (the Internet Explorer engine), in v3 it's being drawn by Qt by way of WebKit. It's a totally different set of code doing the entire UI.
The Qt font engine uses a Windows system call GetGlyphOutline which is supposed to return a bitmap image for a glyph character with gray levels in it for antialiased areas... My guess would be that the new version of Wine is having a problem with this particular call.
6875.64 In reply to 6875.63
I see. That makes sense, then. Thanks for your help! By the way, I will definitely be buying V3 once the student version is available. Currently the bank account isn't quite cooperating either, though. :)
6875.65
Just upgraded my moi 2.0 license to moi 3.0
I had around 100 dollars left in my bank account and spent them for moi upgrade. I'm serious... But don't worry, I won't starve to death, I'll get paid well in 2 days :p
Michael, thank you very much for this awesome program. I hope you never stop developing it. And thanks for your fantastic support!
I'm proud to be a member of this great little community.
See you around fellas :)
- Evren
6875.66 In reply to 6875.65
Thanks very much Evren!
6875.67
Fantastic News!
Just found out today that the update is available - instant buy :-)
Thank you so much Michael for your unparalleled support and dedication.
I no longer do as much 3D as I did before but MOI will always stay with me :-)
Cheers and congratulations to a job exceptionally well done!
Tom
Show messages:  1-18  19-38  39-58  59-67
