Undesired corner points
All  1-4  5-7
6873.5
Thanks for your response bemfarmer.
Thanks for the clarification Michael.
So, is it always a good idea to run "Rebuild" on blended and joined segmented curves, arcs and the like?
Provided you don't want any corner points that is.
scott
6873.6 In reply to 6873.5
Hi Scott,
Yeah usually it is a good idea to use it if you want the segmented joined curve to behave as one single smooth piece after you move some of its control points around in the juncture areas.
In the future I think I'm probably going to try and incorporate some kind of "rebuild and merge segments" type of mechanism directly inside the join command itself.
6873.7 In reply to 6873.6
Yeah, incorporating that into the Join command, would be convenient.
Really enjoying the V3 beta.
I'll definitely upgrade once it's finalized.
Keep up the hard work and thanks again for the clear explanation.
Scott
Show messages: All  1-4  5-7
