Flow question
All  1-2  3-17
6871.3 In reply to 6871.1
Hi Metin, yes it's as eddi says above - surface to surface flow works on underlying surfaces (shrunken down as in ShrinkTrimmedSrf), it does not process something like a trimmed out notch, only the full structure of the underlying surface is used.
You can see the full surface if you turn on the surface control points on your target surface, you'll see that the narrowing edge you have is not part of the underlying surface structure but is instead a trimmed away area.
For contours like that to have an effect in Flow they need to be part of the surface's own control point structure and not a trimmed away detail.
6871.4
Many thanks, Eddi and Michael! I'm learning more about MoI every day.
Would it also make a difference if I'd use the ShrinkTrimmedSurface command on a target surface before performing the Flow command?
6871.5 In reply to 6871.4
Hi Metin,
No, that wouldn't make any difference - basically Flow automatically does the equivalent of ShrinkTrimmedSrf on things already.
ShrinkTrimmedSrf shrinks the "underlying surface" down to the UV bounding box around the trim curves, it still maintains the surface as a net-like grid of control points and won't do something like cut a notch out of the underlying surface in just one local area of it.
So instead you need to use something like loft for constructing the surface so the full surface itself has the boundary contours you want, a trim or boolean used to cut out a notched area will not have any effect for flow because trim and booleans don't modify the "underlying surface", they only create new trim boundaries on top of it...
6871.6 In reply to 6871.5
Fully understood, thanks again. I've done a test, and indeed a lofted surface works as expected, so that's the method I will use from now on to create Flow target surfaces.
Have a nice weekend,
Metin
metinseven.com — 3D (print) modeling • animation • artwork • design • illustration • visualization
6871.7 In reply to 6871.6
another big advantage with loft-command or sweep (with deformed rails and profile),
you can deform uv and get different results by flow-command,
without "base object" modification.
example for loft
before you finish loft-command with "done", move seam-dots direction.
or bevore loft, add more profile.
with sweep, similar, but direct with profile curves.
-EDDI
6871.8 In reply to 6871.7
Thanks a lot Eddi, much appreciated. This gives me a new insight in the way MoI works.
6871.9 In reply to 6871.8
and here is last one example with sweep "area deform",
on picture
Blue lines > Rails
Yellow highlightet > Profiles
-EDDI
6871.10 In reply to 6871.9
Very interesting, thanks for the explanation! I didn't realize yet that you can influence surface topology and its Flow result by a Sweep profiles layout.
6871.11 In reply to 6871.9
eddi, thank you very intresting observation!
My Portfolio: www.samardac.com
A lot of my Tutorials!
Subscribe to my youtube channel: http://www.youtube.com/samardac
Russian community of MOI 3D: www.vk.com/moi3d
6871.12 In reply to 6871.11
1
6871.13 In reply to 6871.12
Hi Andrei,
i do not speak English, only German and Czech, a proper brake here to post.
so hoping for you and your excellent understanding in 3D,
maybe a new theme for your famous tutorials ???
best regards
-EDDI
6871.14 In reply to 6871.13
Hay eddi, I'm not sure I understand what do you mean :)
6871.15 In reply to 6871.14
Hi Andrei,
i mean, you make very good tutorials,
can you make one for the "flow manipulation" ?
this can help other users with FlowPower!
regards
-EDDI
6871.16 In reply to 6871.15
Hi eddi,
I made it already yesterday but not posted it. This is it:
6871.17 In reply to 6871.16
Great video, Andrei! Vă mulțumim!
Show messages: All  1-2  3-17
