how made these complex objects in moi?
All  1-5  6-13
Seems you can do some of them with some repetions of a modules ;)
Use the Transform / Array
6865.7
Grabbed a shape from Photoshop. Saved it as an ai. Import into MOI. Extrude, then Transform Array. Played around a bit. I did have to extrude the item in parts.
6865.8
as Franchy or Mikebres says, here are 1000 possible combinations in Moi3D
Do not forget flow-command (very powerful) in combinations with array and other.....
You can disassemble the case in to parts (if necessary in to ten parts) , flow, array over and rebuild to one object.
There only little limits......if you do not understand how a command works, then noting will help.....
-EDDI
6865.9
here another crazy result, with attached file from previous posting
base surface shorter than FlowObject
and mirrored result
-EDDI
6865.10 In reply to 6865.9
Sweet results! I'm impressed
Kuto.ch / freelance graphic designer and 3D generalist
Very cool!
6865.12
thanks are due to the programmers of the 3d library
tiny remark for this geometry.....
exported wireframe model is very large,
when memory is full with steps "undo, redo, copy",
export (during meshing) can hang
-EDDI
6865.13
Thanx, so I will try some complex-meshes also first with moi and with *.ai ;)
Show messages: All  1-5  6-13
