Side Panel
6861.1
I'm just a bit into customizing MoI and messing around with its UI.
My question is: How to make the side panel that shows styles and objects to be already expanded when opening MoI?
6861.2 In reply to 6861.1
Hi mark, if you leave the panel open when you close down MoI, the panel itself will be open on the next run but there isn't currently any way to make the individual sections like "Objects", "Types" and "Styles" to start out expanded. In the future I want to make those expanded states be saved in a 3DM file and restored when loading the file but currently that is not set up like that.
6861.3
Thanks for the info, Michael.
I have to say, for all the years I already use MoI, I have never seen another developer who is more user-orientated and faster in answering their questions. :-)
6861.4 In reply to 6861.2
Another question:
Where can the border radius and width of the viewport dividers changed?
Size: 8.4 KB, Downloaded: 41 times, Dimensions: 159x146px
6861.5 In reply to 6861.4
Hi mark,
That particular thing is still controlled by a bitmap image, you can edit the file \ui\ViewportForeground.png in an image editor program to alter that.
The image needs to have a line of white pixels on the top and left side, with 2 black dots marking where the corner areas are. The area in between the corners is stretched when the bitmap is drawn.
