Project Parameterization, rocker demo
All  1-5  6-14
6860.6 In reply to 6860.5
> Cannot extract the y value of the points.
> /code
> projectfactory.update();
> var ktpointobj = projectfactory.getCreatedObjects();
> var ktpoint = ktpointobj.item(0);
So here ktpoint is a "point object" which has the standard geometry object properties like style, hidden, name, etc... then in addition to that set of common properties that curves and solids also have, there is an additional .pt property on it that will give back a "data structure point" that has the x,y,z values on it.
So to get the x,y,z values you need to get at the .pt property first, like: ktpoint.pt.y
6860.7 In reply to 6860.6
Thank you Michael.
Adding .pt worked to get the .y value.
The Asserts went away as well.
Also added: curves.sortBySelectionOrder(); from lineweb, to clear up which curve is which.
I am not sure about where and how objectpicker.min = objectpicker.max = 2; fits in.
What is the difference between objectpicker.allowCurves();
and objectpicker.allowStandaloneCurves(); ?
The script is working, in some fashion, but may still need some work tonight.
It is slow in .js
6860.8 In reply to 6860.7
That will make the object picker trigger it's "finished" event immediately after 2 curves are selected, like as soon as the second curve is clicked on, rather than the regular selection path where it waits until the user pushes "Done" (or right-clicks in a viewport as a shortcut for "Done") before the "finished" event is triggered.
allowCurves() means allow any kind of curve including edge curves.
If you instead do allowStandaloneCurves() it will mean edge curves won't be allowed for the pick.
Here is my latest FrenetKTCurve script, which generates a 3D space curve from the 2D curve graphs of Curvature Kappa, and Torsion, Tau.
Thanks again to Michael for much help and explanations of scripting.
Since the script is probably not bug proof, it should not be used with unsaved or valuable work.
A demo curvature and torsion graph of Rudy's Rocker is included. The PI length should be set to 4.0.
The user interface could use an Update button.
The reason for doing the script was to produce a Moebius strip, which it almost will do. The graph of Kappa and Tau is approximate.
The graph is included as KappaVersusS12.3dm. Load it into Moi, then run the script. The PI length should be 1.0, as the second half
of the curve comes out wrong. Kappa of zero can be a problem. The second mirror of the half loft surface almost closes to a Moebius strip.
The trouble with the Frenet frame is getting the curves to close.
A Moebius strip centerline curve, based upon the physics of real materials, has been calculated by E.L. Starostin, and G.H.M. van der Heijden,
defined by Curvature (kappa), and Torsion (tau). The mathematics is advanced, and DAE equations must be solved.
http://www.ucl.ac.uk/~ucesgvd/moebius.pdf (copy to browser)
http://www.homepages.ucl.ac.uk/~ucesgvd/moebius_suppl.pdf
http://arxiv.org/abs/0905.1880
http://arxiv.org/abs/0804.0419
http://arxiv.org/abs/0807.0377
http://onlinelibrary.wiley.com/doi/10.1002/pamm.200700858/pdf
This script does NOT solve the DAE equations to determine the Kappa and Tau curves for a particular width of a Moebius strip of length 2*PI.
Nor does it do a 3-fold Moebius strip. DAE solving may be attempted later. Maple or Mathematica can do it with Runge-Kutta-Fehlberg45.
Solving the DAE equations should produce Kappa and Tau numbers to get a closed curve.
Other Kappa and Tau graphs can be used. The PI length should not be greater than the x values of the curves.
The graphs must satisfy the vertical line test, as there can be only one y value for an x value.
A trial of curves which violate this rule did not crash Moi, but in one case the new curve did not finish.
I want to be able to do a 3-fold Moebius. The papers tell how to do so, but they leave out much information about the actual solving of the DAE equations.
The number of points should be 100 or 200, for a more accurate curve, which takes some time.
EDITED: 16 Aug 2014 by BEMFARMER
6860.10 In reply to 6860.9
Brian,
Would you mind explaining in a little more detail how to use the two .3dm files?
Mike.
6860.11 In reply to 6860.10
Hi Mike
1. Load the .3dm file of a 2D pair of curves into Moi. Front view is good.
2. Start the script. I am using Max's custom UI, having run short of shortcut keys :-)
3. Select the upper curve as Kappa curvature. Select the lower curve as Tau Torsion.
Selection in reverse will create a different curve.
4. Adjust the values appropriately.
PI length is the maximum x value of the 2D curves, and also will be the arclength of the new 3D curve, Currently the script starts running at x=0.
numpoints +1 is the the number of points used to create the 3D curve and lines. The start point accounts for the +1.
The Project command is used about 2 X 8 times per point, to get Kappa and Tau.
Checkboxes are for creating BiNormal lines and/or Normal lines.
Bothsides uses the line factory to extend the lines to the other side of the 3D curve.
User Loft of the lines creates a Ribbon effect.
5. Press the Update pushbutton. It is from the Pipe2 command.
6. Depending upon the Style setup, if there are Normal lines, they will change color a couple of seconds after completion, to the next color.
The Moebius papers talk of using an "anti-Frenet" frame where Kappa is zero. This term does not appear in google searches.
I think that this is an "isolated inflection point." Maybe B and N can be negated there? http://arxiv.org/abs/1302.3175
So there is a lot of room for improvement.
Using a formula for Kappa and Tau would be faster, but I do not have a formula for the Moebius strip centerline.
EDITED: 17 Aug 2014 by BEMFARMER
6860.12 In reply to 6860.11
Added an Update button.
The GetValue( name ) function does not include .integerValue nor .value
6860.13 In reply to 6860.12
Found one more paper on a physical Moebius Strip, a thesis by Coilin P. Boylan Jeritslev.
He uses cubic B-Splines. Page 42 may be helpful, and also shows 3-fold information.
www.coilin.dk/RapportFinal.pdf
6860.14 In reply to 6860.13
Updated script to version 03.
Added start point and end point selection. Did not add check that startpoint < endpoint. startpoint = (0,0,0) typically.
Deleted cLength.
Deleted second half of Kappa and Tau curves.
Adjusted initial values of T, N, and B.
Added an alternate selection of values for T, N, and B, called antiFrenet.
The color g_style_index is not being used correctly. (It is better not to use the second color, usually red, when running the script.)
Running the script, without anti, can create half of a Moebius strip of width 1.6 units.
Rotating the results in top view, from the origin, by 180 degrees, produces the other half of the Moebius strip.
Alternatively, re-run the script with the anti checkbox, will produce the same second half. So anti is not needed.
Loft(s) creates the ribbon(s).
The curves do not quite match up at the inflection point, because the source curves are not quite right,
so a little bit can be deleted from each end, and the ends of the lofted ribbons Blended with G2 curvature.
The centerline can also be blended G2. The Blended strip can have a few points arrayed on its centerline, and isolines added.
The result is not quite perfect.
Show messages: All  1-5  6-14
