Bulged shapes
All  1-2  3-5
6859.3 In reply to 6859.1
If you want to experiment with the 2 rail sweep way, it goes something like this - draw one smooth outline curve for the rails, then use Edit > Trim with the "Add trim points" option to cut it into 2 pieces:
Then to do a sweep along that, draw profile for the cross-section away from the rails, select the profile, run Construct > Sweep and then pick the rails to get a result like this (see 3DM file attached):
This method can be difficult though if the head part kind of tries to bend very sharply on one side...
6859.4
Using Michaels curves in the example you could also Extrude the two curves (caps off) then Blend the two surface edges, gives you a similar result with bulge adjustment.
6859.5
Thank you guys,
very helpful!
Show messages: All  1-2  3-5
