Creating a gap or grove in a shallow angled corner
All
1-7
8-9
BurrMan
8 Aug 2014 (8 of 9)
6851.8
In reply to
6851.6
can you post some example surfaces/walls where inset doesn't work?
This is what needs to be seen....
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
shayno
8 Aug 2014 (9 of 9)
6851.9
Hi Paul
This works
Create the inside surface , separate then select all faces and extrude , from them you can fillet or chamfer the outer edges
I hope this is on the right track
cheers
shayne
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
Reply to All
All
1-7
8-9
