Blend curves
All  1-8  9-12
6846.9 In reply to 6846.7
Yes... what me and Marc said seems to be what you want.
Martin.
6846.10 In reply to 6846.7
Hi boja, maybe you're getting confused since things are structured slightly differently in MoI than in Rhino - in Rhino there are different commands for blending curves versus blending surfaces, while in MoI there is just one Blend command which can work on either curves or surfaces depending on whether you have curves or surface edges selected when you run it.
So you use the Construct > Blend command as shown above to do what you want, just select curves as the input objects for doing the blend.
This type of combining of both curve and surface processing functions into just one single command rather than separate ones is one of the ways that helps keep MoI's UI to be more streamlined and not get so cluttered up.
Blend 2 curves in Moi!
Blend 2 edges : if you don't hide or kill the "Curves" blend surfaces will be failed!
You must have "Edges" writed on the Right top corner info screen!
@ Michael some funny things with Languages enable ! See here Default when English enabled!
Maybe refreshing ?
EDITED: 4 Aug 2014 by PILOU
6846.12 In reply to 6846.10
Great !! Thanks to all. I'm away from modeling due to personal business, so I forgot everything =)
Show messages: All  1-8  9-12
