Nsided help
All  1-4  5-8
6843.5
Thanks, Michael
Your hint was correct, with the into 3 segments trimmed opening the sphere could be closed with nsided.
Not as expected but the shape it generated is very interesting.
The opening divided into 6 parts and then filled with nsided brought a flawless result. :-)
Size: 44.8 KB, Downloaded: 25 times, Dimensions: 785x590px
Size: 42 KB, Downloaded: 31 times, Dimensions: 662x545px
6843.6
Another question I just thought of.
I used rebuild to simplify the point count of the opening a bit.
But there is no rebuild command for surfaces, is it?
6843.7 In reply to 6843.6
Hi mark,
No currently there isn't. In the future I do want to extend the Rebuild command to work on both curves and surfaces but right now it only works on curves.
6843.8
Thank you.
Currently I'm using Rhino to rebuild surfaces. Fortunately you can drop shapes back and forth via the clipboard. So no big deal here. :-)
Show messages: All  1-4  5-8
