ping - Max Smirnov
 1-12  13-32  33-52  53-72  73-87
6837.53 In reply to 6837.51
Hi Max,
Thanks for node editor update.
where we put interface.js and index.htm file ?
6837.54
Frenchy Pilou
>>Does all that (+ nodeditor) works also for the V3 or it's only for the beta V 4 ?
Yes. The current version of nodeeditor are fully compatible with all v3/v4 win/mac MoI versions.
Finema
nodeeditor/nodes/interface.js
nodeeditor/index.htm
6837.55 In reply to 6837.53
Hi Finema,
just there:
Ralf:)
looking for moments of inspiration...
6837.56 In reply to 6837.55
Thanks Max & Ralf :)
Hi Max,
In either MoI3, or MoI4beta, if the MoI window is not maximized,
and the External scripts screen is too big, or bigger in size,
(Mine has about 395 files in it.),
Then the external scripts screen only shows when the left (or right) mouse button is held down.
6837.58 In reply to 6837.54
Hi Max,
I would like to get your thoughts on the idea of making a small alteration to Widget/Knob.
Often in developing node circuitry, There is the need for dialling even integers only ( or at other times, only odd numbers). This could easily be achieved by changing the "Digits" field to an "Increment" field, as shown:
The default setting of course would be 1, and Decimals could also be accommodated, for example, using 0.01 instead of 2 as presently used to represent the same. I also think it is more intuitive.
I understand that making this change couldl create backwards compatibility issues, but perhaps this could be avoided by having RMB options of Digit (Default) and Increment (2nd option).
Thanks for your continued development
I am excited to get my hands on v1
P.S. Also sometime ago we discussed the inclusion of button & switch, that you had planned to repurpose code that you have already developed for a different application.
http://moi3d.com/forum/index.php?webtag=MOI&msg=7713.689
Another revision that would be simple (I think) but very useful would be to use createRadialGradient() method to lay a radial gradient (dark grey to light grey) behind grid in NE interface. This would offer visual cue to locate area within main window in reference to the totality. At the moment, at time when you fully zoom out, if nodes are not shown, there is no way to be sure which way to pan to move towards the centre to find node circuitry. Of course a "zoom to extents" function would be better but also more involved (I imagine)
EDITED: 7 Dec 2017 by JFH
6837.59
Sorry, I was extremely busy last week.
Brian
I can't reproduce it. Anyway I use MoI's built-in functions to show the window, so I can't fix this issue by myself.
I need to significantly change all widget nodes to implement this feature. Sorry, I can't make it in the nearest future.
I rewrote this node for using with NE.
You can download an updated interface.js from my site: http://moi.maxsm.net/nodeeditor/
I'll add this feature in the next NE release.
6837.60 In reply to 6837.59
Max
Thanks for switch node, it is masterfully resolved & will be very useful.
>> need to significantly change all widget nodes to implement this feature. <<
Is this also true if feature is a RMB second state option of knob only?
Thanks again for your continued development of NE
6837.61
Hi Max,
is it possible to have a feedback node similar to Hoopsnake as discussed in the nodebundle thread.
Ref this video https://www.youtube.com/watch?v=QefqhzIz_ak
Barry
6837.62 In reply to 6837.59
Wow thats a nice switch/button..
Thanks a lot Max!
Ralf:)
6837.63 In reply to 6837.60
Hi Max,
RE: NE interfacing via trackpad issues
Problem appears to be fixed...
see http://moi3d.com/forum/index.php?webtag=MOI&msg=7713.783
EDITED: 31 Jan 2018 by JFH
6837.64 In reply to 6837.63
Hi James,
I'm glad that problem is solved. I'll add this fix to the next NE release.
Hello Max.
With the latest V4 and the latest version of your _sSplit.htm command I get this error after selected one face of the box and fired the command :
Ciao!
Marco (mkdm)
6837.66 In reply to 6837.65
Hi Marco,
I can't reproduce this error. It seems you have an old version of the script.
Update it from my site: http://moi.maxsm.net/item/45
6837.67 In reply to 6837.66
Ok. ASAP I will do. Thanks.
6837.68 In reply to 6837.66
Done!
Now all is ok both in V3 and V4.
Thanks a lot!
Hello Max.
While surfing the web searching a tool that I need actually for my daily software developing,
I accidentally found this : https://pressurejs.com/
And it occurred to me the topic you were talking about some days ago : "touchpad gestures"
I don't know that product (https://pressurejs.com/) but it may help you for what you want to do.
If you want, give it a chance. It's free.
Ciao!
Marco (mkdm)
EDITED: 15 Feb 2018 by MKDM
6837.70 In reply to 6837.69
Hi Marco,
thank you for this link, I'll check this library and maybe I'll find something interesting.
However, I have no plans to use this library in my projects. In the cases when I can write a code by myself, I prefer to not use external libraries and frameworks.
6837.71 In reply to 6837.70
Hello Max!
@You : "...thank you for this link, I'll check this library and maybe I'll find something interesting...."
You're welcome.
Ciao!
6837.72 In reply to 6837.71
Hi max,
Have you update Heightmap for V4 ?
Thanks a lot.
Show messages:  1-12  13-32  33-52  53-72  73-87
