Fillet Question
All  1-11  12-16
6806.12 In reply to 6806.11
VERY COOL, OSTexo !!!
I took the easy way out .... lol
Not what I exactly wanted but I can live with it.
I like your solution better.
Size: 850.5 KB, Downloaded: 56 times, Dimensions: 1920x1080px
Size: 856.1 KB, Downloaded: 50 times, Dimensions: 1920x1080px
Size: 822.4 KB, Downloaded: 65 times, Dimensions: 1920x1080px
6806.13
Hello,
Glad I could assist. I'll have to keep this technique in mind in case I run into a similar issue with filleting.
6806.14
I down loaded a trial version of ViaCad and stumbled my way through to get something close to what I have in MoI. It gave the same result as MoI
but it did allow me to radius the outside edge (0.5 R) where as in MoI, it tried, but it didn't finish the deal ...
Size: 516.1 KB, Downloaded: 50 times, Dimensions: 1920x1080px
Size: 221 KB, Downloaded: 52 times, Dimensions: 1920x1080px
6806.15
Hello jetblast,
You could keep that fillet that MoI generates and use it to Trim away and delete the undesired part of the solid. Then try to Join that fillet to the rest of the surface to see if it's watertight.
6806.16 In reply to 6806.14
Hi jetblast,
It looks like MoI's filleter got confused in the part of the process where it cuts away space in the main object.
When it runs into an error like that, it still returns the fillet surfaces that it was able to generate so you can use them, like OSTexo mentions above you can probably use the Trim command to cut the main object and then join the fillet into place in that case.
The geometry library that ViaCAD users does tend to handle a lot more fillet corner juncture type cases than MoI's though so it's not a bad idea to use it to assist with filleting like that.
Show messages: All  1-11  12-16
