Variable Fillet Radius Problem - V3 June
All  1-2  3-8
6805.3
Hello,
You could also try sweeping a variable set of circles around that edge, trimming away the swept surface from the solid and then using the blend command to blend in the resulting edges. It's a little more work but it creates a nice solid result.
VRF
EDITED: 3 Feb 2025 by OSTEXO
6805.4 In reply to 6805.1
Hi Kevin, when you don't see anything happen at all after adding some points, (like no "Calculation failed" message) it could mean that the filleter does not think those points are on those edges (may be a tolerance thing related to the small size of the part too), I'll investigate it some and see if I can find out what's going wrong there.
6805.5 In reply to 6805.1
Hi Kevin, ok so it's a bug - since fillets at a small radius value have a tendency to not work very well, the filleter has a mechanism where if you use a fillet radius smaller than a certain size, it internally scales the model upwards and does the fillet at a larger scale, then scales the result back down again.
The bug is that when this internal scaling is being applied, it wasn't getting applied to the point set points and so it didn't think the points were on the edges.
I've got this tuned up for the v3 final release so your posted case will work properly there. In the meantime if you scale it up by 10x in size and do the filleting on the up scaled version, it will avoid triggering the internal auto scaling mode and not trigger the bug.
Thanks for posting the file, it's good to get this fixed up before the v3 final release.
6805.6
Doh, I keep forgetting about the need to work in the 1 to 1000 range for the model size. Michael is that still the case in V3 ?
Thanks for reminding about it.
~Kevin~
6805.7 In reply to 6805.6
Hi Kevin,
There's been progress in V3 to make various things more adaptive to object sizes rather than using only a fixed fitting tolerance, but it's still possible to run into problem areas.
Your particular case here was just a bug - I've fixed it up for the V3 final version so your original case at your original small size will work ok.
6805.8
Ok, thanks Michael
Being able to work at any size is a big plus.
~Kevin~
Show messages: All  1-2  3-8
