Bevel gears
All  1-10  11-17
6736.11 In reply to 6736.9
Great! I'll try and get my mind around this tomorrow.
Mike.
Cool!
Moi (very low Poly) -->Sketchup+Lightup a very funny Render "real time" of all the 3D scene
after a little calculate you can Move, Rotate, Resize, Walkthrough... the scene, "render is always yet done" !!!
EDITED: 31 May 2014 by PILOU
6736.13 In reply to 6736.12
You may try to consider lofting 2 gear profiles. I think using extrude method is morphing the gear splines...
6736.14 In reply to 6736.12
What a fantastic imagination you have, Frenchy!
Mike.
6736.15
Thank you all for your suggestions and help.
I've achieved results good enough for my purpose which is 3D printing.
I choose a 12 tooth pinion and a 30 tooth gear using Module 2 meeting at 90 degrees.
I used the formulae from the info that Brian supplied to calculate angles - see below
Basically I trimmed one gear profile from the spur gear script output, extruded it to a point, laid it down on a cone and arrayed the extruded profile around the cone.
I think that it's a bit of a bodge because I couldn't find a way to extrude to the point that I wanted to extrude to which was vertically above the pitch circle I could only extrude to a point vertically above the centre of the bounding box - auto chosen (as far as I could tell) by the extrude-to-a-point function. This introduced a very slight error that I had to fudge my way around.
Images below and file attached.
Mike.
6736.16 In reply to 6736.15
Hi Mike, re:
If the auto chosen tracking line is not what you need, you can make extrude to point freely pick the point by pushing the "Unlock direction" button in the command options:
6736.17 In reply to 6736.16
Aha!
Thank you, Michael, I hadn't noticed that.
Great.
Mike.
Show messages: All  1-10  11-17
