UIProgressBar?
All  1  2-3
6733.2 In reply to 6733.1
Hi mushcraft,
> Are there any examples out there on how to use UIProgressBar?
You declare one like this:
<moi:ProgressBar id="progressbar"/>
Then it has a .value property which can be a number from 0 to 100.
> And/or how to update the "Calculating..." display?
That's built into the geometry factory mechanism, it gets set automatically if an asynchronous geometry factory is taking a while to finish.
It should be possible for a script to show it too though, use this for showing it:
var CalcDiv = moi.ui.sidePane.document.getElementById( 'Calculating' );
CalcDiv.style.display = 'block';
And for hiding it:
CalcDiv.style.display = 'none';
6733.3 In reply to 6733.2
Perfect, thanks!
Show messages: All  1  2-3
