Loft Tangency.
All  1-2  3-4
6726.3 In reply to 6726.2
Thanks for replying, Michael.
I think blend will give me a good result for the job in hand, but I was looking for a way to move, resize or reshape the lofted curves and have the shape update whilst remaining tangent to a previously made surface without having to undo and redo the blend.
I sometimes need to adjust things like this when I reverse engineer old components for moulds that I make.
Martin.
6726.4 In reply to 6726.3
Hi Martin,
Well it is possible to have blend update by the history mechanism... If you do something that changes the surface on either side of the blend, the blend will recalculate itself without you needing to undo and redo it separately. That's usually only if you do your edits right after the blend has been created before doing any other trimming, boolean, or joining operation on the objects though.
Show messages: All  1-2  3-4
