Object names and OBJ export
All  1-3  4-6
6719.4 In reply to 6719.3
Hi Shapenoid,
> would it be feasible in the future to be able to export as .obj in clipboard?
> And paste in C4D? Or is that specific to every 3D software?
As far as I know there isn't any standardized way to put .obj format data into the clipboard. Normally 3D programs store clipboard data in their own private data formats, unless they have gone through some trouble to publicly document the structure of the clipboard data.
But you can get a similar effect by just using a specific file, like set up a shortcut key in MoI that exports to a hard coded file name, which you can do by putting the file name in the "Command" part of the shortcut key like this:
Export /Users/michael/testfile.obj
Then when you trigger that file, it will use that specific filename and not prompt you for a file name.
Then inside C4D set up a shortcut that reads in that specific file, that will then work similar to copy/paste using that one file as the clipboard.
> And is it possible to change my forum username to Shapenoid without the DesuDeus?
I'll see about changing that.
6719.5 In reply to 6719.3
DesuDeus is your log-in name - I can change that to also be Shapenoid in which case it will only show just one plain "Shapenoid" in your posts here, but you will also need to change what you put in the login prompt for signing in, so I will wait until I know you've read this so you know you'll need to change how you sign in.
6719.6
The script idea is neat!
I'll try that!
Yes you can change my username :)
Thanks a lot for everything, MoI3D has the best user support I've ever seen in my whole life (even if I'm young haha)
shapenoid.com
Show messages: All  1-3  4-6
