ornaments - looking for an advice
 1-5  6-22
6713.6 In reply to 6713.3
Thanks for your prompt reply.
I downloaded sculptris and saved a file in .obj (I have no other choice beside Zbrush type)
Can you suggest me how can I convert this file in order to import in moi3d ?
Thanks for your help
6713.7 In reply to 6713.6
I think it is practically impossible to convert high polly model from Scultpris to nurbs in good quality. But there was some plugin for rhino, that some how converts high poly, I do not remeber the name of it. I thinnk it is not the best way to go. Why not to stay in poly?
6713.8 In reply to 6713.6
Hi matur61,
Sculptris works on polygon mesh data, it's a different type of model data than the NURBS surface type of data that MoI is designed to work on.
MoI can convert it's own large spline surface sheets into polygons for export by dicing them up into little pieces, but it's not so easy to go the reverse way and take already diced up little facets and convert those into larger sheets. There is some specialized reverse engineering software that can do that, but it involves quite a bit of work and the software is expensive, it tends to be more meant for helping to convert 3D scans into CAD data.
So usually if you are working with polygon mesh type data, you will not be able to bring that data into MoI. You can export polygon data out from MoI but not import it back in to MoI.
There are some exceptions to this in certain special cases like if you're working with subdivision surfaces for the polygon data and use the T-splines program to convert it, but that probably won't be an option for using with Sculptris.
So you'd mainly focus on doing your entire job in Sculptris and not bringing that object into MoI at all...
6713.9
Hello matur61,
You could probably create a curve set in MoI and import that into Rhino and use TSplines to build this out, or just import the image reference into Rhino although I find the image options in MoI a little more friendly. If you want that model as NURBs it's counterproductive to model that in a poly modeler and the import it into Rhino with TSplines, just model that in Tsplines, you'll end up with a much cleaner result and you'll be able to modify that design with much less effort if you'd like to move points around.
6713.10
Guys from our Russian community made this staff using MOI. They used sweep....
h8m56mi Ceo
Je 2m0m100c
jr Al OJul AZE
k0ay V Jz VU0
Pr V9 Tq R Vm M
Very neat results!
6713.12
Those Russians... Damn!
Lovely results
shapenoid.com
6713.13 In reply to 6713.10
Thanks for these examples.
I'm quite new to modeling and I'll explore the sweep possibilities.
Are you aware of any tutorial or How To around the web regarding the images (or similar) you posted?
Thanks in any case for your kind help
6713.14
Andrei,
Very hard to wrap my mind around the idea of Sweep getting those results. Beautiful!
Ron
6713.15 In reply to 6713.13
How do you intend to use the model?
If it's for a rendered image, modeling in polys will give you better results for less effort/time.
If you need the model to actually make a physical part, there are reasons for choosing to model in polys or nurbs
3D printing and CNC routers can use polys to make parts in plastic or wood.
If the need is to make a steel mold (ie. for injection molding, some types of casting, or stamping) or a steel part, then you will need a nurbs model. Although milling machines that cut steel can use polys, the poly model is almost universally rejected for this.
6713.16 In reply to 6713.15
My goal is to use these models to make parts both with a router and 3D printing.
Definitely I want to add to my CAD project (I use Alibre, now Geomagic)
For sure I'll continue to use moi3D but if there is a more suitable software, for these purposes, to insert in my pipeline I'd
be greatful if you could suggest me some hints.
Something like Zbrush can maybe help you :)
http://forum.zbrush.fr/index.php?topic=8210.0
6713.18 In reply to 6713.17
Is there a valid cheaper alternative ?
If there is , of course.
6713.19 In reply to 6713.18
Blender or Sculptris are free! ;)
http://www.blender.org/
http://pixologic.com/sculptris/
6713.20 In reply to 6713.18
Also 3D-Coat has a similar type of displacement brush stroke type approach.
http://3d-coat.com/
6713.21 In reply to 6713.16
Producing these ornamental designs as polygon models can be more time efficient, and give you a more fluid result, than what you would get with nurbs.
One advantage of using nurbs in this situation is if you wanted to reuse the models at a variety of sizes.
If you model in polys and discover later that you need to reproduce your model much larger, you would then have to increase the number of polys in your model so you don't see them in the finished part. While this can be done fairly quickly and with good results in many poly modeling applications, at some point the size increase might require rebuilding the model.
Another advantage of nurbs is that boolean functions like joining or subtraction typically don't cause issues for 3d printing. However, these functions can break solids in a poly modeler, so they might need to be repaired in a specialized program so they can be printed successfully.
6713.22
Hi matur61,
Here's a video by a friend showing how he went about making a fleur-de-lis using Rhino.
Although your design is much more complicated, hopefully this video will be of some use.
http://www.youtube.com/watch?v=qv6Sui8SR78
regards Colin
Show messages:  1-5  6-22
