automatic import of subfiles
All  1-2  3-5
6708.3 In reply to 6708.2
so easy..
but i thought more complex.. something like this:
script:var pf="/Users/user/Documents/CAD/";var d=".3dm";var a = ["achswerkzeug", "achshuellen", "reiter"];for ( var i = 0;i < a.length;++i ) { var pfad=pf+a[i]+d;moi.geometryDatabase.fileImport(pfad);};
Now (or before) something to delete the existing objects and than an other short key to export the objects to the part files......
6708.4 In reply to 6708.3
Hi Ralf,
That will work but just one thing to note is that having something alter geometry in an "instant script" like that rather than as a command will not have undo records created for them.
If you want to make it so that import will work with undo, take that same script and put it in a separate .js text file, and then put that file in the \commands sub-folder. Then in the shortcut key put the plain file name (no path and no .js file extension) as the command part of the shortcut key.
One of things that happens when stuff is run as a "command" is that the undo system is initialized and watches for changes to geometry and then creates undo records when the command ends. In the future I want to change this so that instant script would have undo records created automatically as well but currently they don't.
6708.5 In reply to 6708.4
Michael, you are the best! :-)
THX a lot
Show messages: All  1-2  3-5
