automatic import of subfiles
All  1  2-5
6708.2 In reply to 6708.1
Hi Ralf, yeah it could be possible to set up a shortcut key to import a specific file.
To do that, go to Options > Shortcut keys, and add in a new shortcut.
For the "Key" column put in whatever key you want to trigger it, and for the "Command" column put in Import followed by a space followed by the specific file name, something like this for example:
Import c:\parts\Part1.3dm
Then when you trigger that key, it will directly import that specific file instead of asking you for a file name.
Be careful not to trigger it multiple times in a row or else you'll get stacked up duplicate objects.
6708.3 In reply to 6708.2
so easy..
but i thought more complex.. something like this:
script:var pf="/Users/user/Documents/CAD/";var d=".3dm";var a = ["achswerkzeug", "achshuellen", "reiter"];for ( var i = 0;i < a.length;++i ) { var pfad=pf+a[i]+d;moi.geometryDatabase.fileImport(pfad);};
Now (or before) something to delete the existing objects and than an other short key to export the objects to the part files......
6708.4 In reply to 6708.3
Hi Ralf,
That will work but just one thing to note is that having something alter geometry in an "instant script" like that rather than as a command will not have undo records created for them.
If you want to make it so that import will work with undo, take that same script and put it in a separate .js text file, and then put that file in the \commands sub-folder. Then in the shortcut key put the plain file name (no path and no .js file extension) as the command part of the shortcut key.
One of things that happens when stuff is run as a "command" is that the undo system is initialized and watches for changes to geometry and then creates undo records when the command ends. In the future I want to change this so that instant script would have undo records created automatically as well but currently they don't.
6708.5 In reply to 6708.4
Michael, you are the best! :-)
THX a lot
Show messages: All  1  2-5
