New Jun-12-2007 beta available now.
 1-7  8-27  28-36
670.28
I'm having a look at PDF import and it doesn't appear work at all. I have been trying out a lot of file but none of them seems to be loaded although they are processed fine in Rhino. Could you post any PDF file that works?
Petr
670.29
Hi Michael:
As soon as I saw the new features, I though to take the hull up. :-)
I´ll tell you about that...thx
to tyglik: Yesterday night I made a probe. The "normal" pdf (like a document) doesn´t work, obviously. :-). After that I tried with an AutoCAD drawing converted to a PDF and it worked.
I send you the file:
Bye!
What is exactly the format PDF who is not the normal "document" format?
670.31
Hi Pilou:
I wanted to say with a "normal" document, the text document write in MSWord or any word processor.
The thing is that I have been trying to import pdf, and the most of my pdf are text documents and they weren´t work.
Now I have been using the WordArt and drawings tools of MSWords and they works, but it isn´t very interesting, actually :-)
Bye!
670.32 In reply to 670.27
Hi Thor, if you have welding turned on MoI does not write UVs to the .3ds file at all...
That's because .3ds does not have a proper way for 2 faces to share the same 3d point, but have different UV coordinates. .3ds has a limitation that it can only specify one single UV coordinate for each 3d point.
If you turn off welding, then UVs will be written because points are not combined into a single point along common edges.
OBJ doesn't have this limitation. In its structure, it has a way to have polygons share one single 3d point, but have different UV coordinates for each polygon.
.3ds is limited in other ways too, like it has a limitation of only having a maximum of 65535 points for a single mesh. If your program supports OBJ, I would recommend focusing on using that since it doesn't have these limitations. Only try to use .3ds if you don't have any other option.
670.33 In reply to 670.31
Hmmm... Actually, I have also tried MSWord's drawing tools, but it failed as well... It looks like the pdf driver could cause the trouble. I use Adobe Acrobat 5.0 Standard Edition. -Petr
670.34 In reply to 670.28
Hi Petr, can you please send me a couple of the PDFs that don't work? (David posted one that does work)
I had tested this with .ai files saved from Illustrator CS that were set as "PDF compatible". I assumed that PDFs would also follow this same structure, maybe something is slightly different.
PDF is a pretty difficult format to support well, it's structure is pretty complex. It will probably take some tuning for it to work better.
670.35
Hello:
This is a file created with MSWord and converted with ALLPDF (you can try to convert online here https://www.pdfonline.com/convert_pdf.asp)
Bye!
670.36 In reply to 670.34
Hi Petr, I tried some more PDFs over here and I fixed up some bugs. I think it should be working a lot better now.
I put up a patch here: http://moi3d.com/beta/pdf_ai_patch.zip . If you download that, it contains a new moi_lib.dll file, just copy it over top of the one from the last beta and PDF import should be working better for you. Please let me know when you get a chance to try it next week. Thanks!
Show messages:  1-7  8-27  28-36
