Curve from two surface intersection
All
1-4
5-6
OSTexo
15 May 2014 (5 of 6)
6698.5
Hello,
You could try the Network command instead, it gives a better result. I used Network, Mode Uniform, Point Count 5 and it gave a very nice result. if you needed to trim that screw it also trims cleanly, no wobble at the top and bottom.
EDITED: 3 Feb 2025 by OSTEXO
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
Sharif (SR13765)
15 May 2014 (6 of 6)
6698.6
In reply to
6698.5
Hi OStexo;
This worked perfectly.
Thanks!
-sharif
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
Reply to All
All
1-4
5-6
