Curve from two surface intersection
All  1-3  4-6
6698.4 In reply to 6698.3
Hi Michael;
The orange surface created by sweep a straight line along a curve. I noticed that when I set the sweep option twist to flat I get the bump/wave at top and bottom of the surface. If the sweep option set to freeform the resulting surface is perfectly smooth. Is there any solution to this?
-sjharif
6698.5
Hello,
You could try the Network command instead, it gives a better result. I used Network, Mode Uniform, Point Count 5 and it gave a very nice result. if you needed to trim that screw it also trims cleanly, no wobble at the top and bottom.
Curve
Curve 2
EDITED: 3 Feb 2025 by OSTEXO
6698.6 In reply to 6698.5
Hi OStexo;
This worked perfectly.
Thanks!
-sharif
Show messages: All  1-3  4-6
