Unwrap
All  1-3  4-8
That's tricky use of the versatile Flow function! :)
6679.5 In reply to 6679.2
Thanks for the replies,
Actually I was thinking ahead a little. I was thinking of the large and variable fillet that goes between an airplane wing and its fuselage. I could model it rather easily but if I wanted to build the plane then I would need a template of the flattened fillet so that I could lay it in place. I could (and probably will) fill it with balsa pieces and then use some wood filler and then then sand to shape but it would be really cool to lay a pre cut piece in place and bend it back to shape.
Thanks again.
6679.6 In reply to 6679.5
Hi bz, a fillet like you're describing is not a developable surface, which basically means it's not physically possible to form it out of a flat piece of stock and then only bend it into shape along a straight edge.
Any surface that has compound curvature in it rather than being straight in one direction cannot be formed from a flat piece without having lateral stretching taking place at the same time.
That's part of why the whole area of surface unrolling for physical construction is a fairly complex topic.
Your 3D surface has to have the shape of something similar to a cone or a piece of a cone in order for it to unroll to a flat pattern.
6679.7 In reply to 6679.5
Rhino has some tools in it for working with developable surfaces, some info here:
http://www.rhino3.de/design/modeling/developable/
http://wiki.mcneel.com/labs/devsrf
http://docs.mcneel.com/rhino/5/help/en-us/commands/unrollsrf.htm
Here you'll see how a complex curved surface made from bent planks does not really happen with a single bent piece, rather it's a set of strips with each individual strip being a developable surface:
http://www.boatdesign.net/forums/boat-design/designing-developable-surfaces-rhino-45275.html#post592264
Just any curved surface is not likely to be developable, especially a fillet going around a curved shape is not going to have a straight line shape to it in any single direction, in order to unroll a surface it has to have that straight line on it which is where it would be bent at in order to roll it up.
6679.8 In reply to 6679.7
Thanks Michael, your explanation makes perfect sense ...
bz
Show messages: All  1-3  4-8
